need data about it
Sarunas
Sarunas Posts: 9
edited November 2014 in Basic Hookup/Wiring Questions
Hi everyone...
Im new at this forum... from Europe... Recently I bought vintage polk audio system:
satelites - RM II series - 4 psc.
center - RM II series - 1 psc.
subwoofer - ???..see at picture.
Need help about that system... technical data, resistance of speakers, power...etc. Where i can find it?what type is that passive subwoofer? What power amplifier is optimal for that?
thanks
Sarunas
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2014
    Hello,
    Welcome to Polk's forum. This link should be helpful:
    http://www.polkaudio.com/products/rm5000
    Regards, Ken
  • Sarunas
    Sarunas Posts: 9
    edited June 2014
    Thank you Ken... it help me a little.... really old system...:) information about it very hard to find...
    thanks.
    Now looking how i can mount satelites on wall...any ideas?
    Sarunas
  • [Deleted User]
    edited June 2014
    Hello,
    You should be able to use the OmniMount OM10 wall mount bracket. Or, any suitable wall mount bracket that uses a 0.25" diameter hole with a #20 thread to attach to the speaker.
    Regards, Ken
  • Sarunas
    Sarunas Posts: 9
    edited June 2014
    Thanks Ken...
    a first problem here - hub tread at speaker back...:) different standart then at europe...and unknown corps material...very heavy...
    Now looking bolts ...maybe find american standart...after - mount bracket...
    What can i say about polk audio rm II... sound very clear...bass deep and clear...at this moment like amplifier I using simply philips micro system mcm760(http://www.usayd.com/2007/01/14/review-philips-mcm760-micro-hi-fi-system/) ...and conect laptop(player foobar2000) and listen lossless...
    thanks...
  • [Deleted User]
    edited June 2014
    Hello,
    The threaded opening is very common in America, 1/4" diameter and 20 threads to the inch. I don't believe there will be a metric bolt that will fit it.
    If you are unable to find this size speaker bracket try looking for a bracket that grips the speaker across the bottom, but because of the rounded sides of the enclosure make sure the speaker is secure.
    The satellites are made of a type of synthetic marble material similar to Corian, this is done to make the enclosure rigid and inert. This will reduce unwanted cabinet resonances which can add coloration to the sound. Also the tweeter is recessed 1" behind the midrange driver. This is done to "time align" the two components and produce a more coherent sound quality.
    Enjoy, Ken
  • Sarunas
    Sarunas Posts: 9
    edited June 2014
    Thanks for information Ken... my turn now...:) really for better sound quality at future I plain Creative Sound Blaster Audigy 2 ZS Notebook Sound Card PCMCIA...
    by...Sarunas
  • Sarunas
    Sarunas Posts: 9
    hello Ken...
    sorry ... new style forum I see... and dont working old link(http://www.polkaudio.com/products/rm5000)... maybe can help me again? Really i need how much ohms and wat have subwoofer and sattelites(It help me to choise a stereo receiver)
    thank you...
    Post edited by Sarunas on
  • Hello,
    Nice avatar! The old product information doesn't function once the old web site was closed. Are you looking for anything specific?
    Regards, Ken
  • Sarunas
    Sarunas Posts: 9
    thanks Ken,
    yes i looking old produkt technical date... (https://us.v-cdn.net/5021930/uploads/attachments/2/2/8/2/1/7/92417.jpg). All technical date about this system.
  • Hello,
    Here is the information:
    Driver Complement:
    Satellite speakers:
    Tweeter component:
    Quantity 1
    Diameter 3/4" (1.91cm)
    Midrange component:
    Quantity 1
    Diameter 3 1/2" (8.89cm)
    Center speaker:
    Tweeter:
    Quantity 1
    Midrange:
    Quantity 2
    Subwoofer:
    Quantity 2 active drivers:
    Diameter 6 1/2" (16.51cm)
    Passive radiator:
    10 passive radiator
    Electrical:
    Total Frequency Response 25Hz - 20.5kHz
    Lower -3dB Limit 42 Hz
    Upper -3dB Limit 18 kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 25 - 250 watts per channel
    Regards, Ken
  • Sarunas
    Sarunas Posts: 9
    wow...thank you Ken... you help me really...(maybe you know how much watts have speakers(satellites, center and subwoofer?))
    hmm... sorry...cant understand about subwoofer a little..."Passive radiator:
    10 passive radiator"?
    mhardy6647 Posts: 35,259
    A passive radiator is in essence a speaker cone with out the electromagnetic motor (magnet and voice coil) part of a regularspeaker driver. It is passive (not driven by the electrical input signal). Physically, it acts analogously to the 'port' on a bass reflex speaker enclosure.
  • Thanks, mhardy6647....I understand than subwoofer is pasyve... just interesting what inside sub box...and how it work... maybe someone have inside pics or something?
  • [Deleted User]
    Hello,
    The two 6.5" active drivers, in the sub-woofer, provide the changes in internal air pressure that cause the 10" passive radiator to function.
    Regards, Ken
  • Thanks Ken...well I see its not traditional system of subwoofer... very interesting...maybe somewhere i can find scheme?
    Sarunas
