Sunfire question
bluecomet
bluecomet Posts: 1,118
edited June 2014 in Electronics
I have a Sunfire 2 processor that I am going to connect to a Sunfire Grand Theater amp. It has a RCA type connection and a XLR connection. What are the differences in sound quality between these types of connections.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2014
    The balanced XLR connection is great if you have an extra long run between the amp and pre-amp. The RCA inputs will do just fine for shorter runs. You will have a few extra Db input using the balanced cables, over RCA cables. Here is a thread that might answer some of your questions.
    http://www.polkaudio.com/forums/showthread.php?8628-Balanced-(XLR)-vs.-Regular-RCA&
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • bluecomet
    edited June 2014
    Thanks for the link. It was very informative.
    nooshinjohn Posts: 25,901
    edited June 2014
    According to Bob... no difference at all, especially on a short run. Of course, Bob thinks 16G lamp cord and MIT speaker cables sounds the same as well.:lol:
  • bluecomet
    edited June 2014
    I was looking at the owner's manual on line for the Sunfire grand theater processor on line, it said if you are able to connect the xlr
    cables to your amp, which is a Sunfire, you will get better sound quality. Maybe someone else is writing the owners manual. The
    Sunfire amp I am using is your old one you had autographed by Bob. I also have your modded SRS 1.2 tl's I enjoy very much. I hope to meet Mr. Carver some day, maybe he can autograph my Sunfire processor.
    EndersShadow Posts: 17,702
    edited June 2014
    bluecomet wrote: »
    If your close to Jesse (F1Nut), or George Daniel maybe see if they would take your processor down to Carverfest and have it signed. I think Bob will be there this year, but haven't been following too closely...
