Shiva Mark IV as replacement
I'm very interested in putting the Shiva in my Infinity BU-2 sub box. Will it work O.K.? Size looks to be no problem. More worried about the amp. Thanks!
Post edited by David Edwards on
  • gatemplin
    gatemplin Posts: 1,595
    edited February 2004
    Hi Dave,
    It's not a very good idea. The tuning will be way off and the box is too small. The amp will have bass boost. If you want a Shiva take a look at the provided designs on Adires Website. Parts Express has some cheap amps and so does Adire.
    Graham
  • goingganzo
    goingganzo Posts: 2,793
    for not that much more and very little work you can do a sealed new sub that you can port later. just get sono tube and some mdfb cut 2 circles and a 3 on one ends install in sono and you have sub.
