TAudioConverter 0.9.4 (0.9.5Beta) - Multithreaded Audio Converter-Extractor CD rippe
WendyAGoss
TAudioConverter is a audio converter and extractor. It can convert almost any audio format to aac, ac3, mp3, flac, wav, ogg, opus, mpc, tta, tak, alac, wavpack. SoX is used to apply effects such as normalization, volume change etc. It can also extract audio streams from video files and encode them. Video files with more than one audio stream is supported.
It is possible to run up to 16 simultaneous processes to shorten encoding time.
If you want an encoder to be added please let me know.
Screenshot:
You can download it from homepage.
Both portable and setup versions are available.
Beta builds can be found in bitbucket page.
Also you can see source code from here.
Suggestions and bug reports are more than welcome.
Screenshot:
