turntable anti-skate qustion
laotzu61
laotzu61 Posts: 327
edited June 2014 in Electronics
I recently picked up a kenwood kd-2000 turntable in really good shape, but it is missing the anti-skate weight. my question is can I use the table without the weight if I track at maybe 3 grams, and/or does anyone happen to know where I may be able to locate one? thank you.
"The symbol is not the reality"
Post edited by laotzu61 on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited June 2014
    you can fabricate your own makeshift weight with fishing line and a lead sinker. Try different weights to see what works best....YMMV.
    I did it once on an older Kenwood and it worked fine.
  • voltz
    voltz Posts: 5,384
    edited June 2014
    That is about all there is to my "Pro-ject" Carbon TT ani-skate. just a little black bead hooked to fishing line.
  • laotzu61
    laotzu61 Posts: 327
    edited June 2014
    thanks, guys. I appreciate it.
    mhardy6647 Posts: 35,161
    edited June 2014
    ... or just go without. Seriously.
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2014
    What I wouldn't do is track at 3 grams unless you have a cartridge designed for that weight. Too much weight wears out the stylus and your records quicker. Check Ebay for turntable anti-skate weights. You may even find an original. Good luck!!
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
