Updated power cords, ICs and speaker cabling. I am ready to believe.
ROHfan
ROHfan Posts: 1,014
edited June 2014 in 2 Channel Audio
I was going to post this in the power cord upgrade thread but I feel it would have hijacked it so I made a separate thread here.
Harry (pohlrbear) here has loaned me his Pangea AC9 to fool around with for a while. First I tried it with my Emo XPA-2. My son and I listened to "Black Cow" by Steely Dan with the stock cord then swapped in the AC9. We acknowledged there was a difference, but it was hard to put a finger on what the difference actually was. I had read somewhere on the forum that using an updated power cord on the source would yield good results so I put everything back together and swapped out my Oppo's power cord for the AC9. Now we were hearing something different for sure. It would be difficult to state exactly what was going on without doing a blind A/B test but the music seemed to have more "snap" to it. Bass was a little more authoritative and horns had a little more "air" around them whereas before they had gotten a little lost in the mix. Although vocals seemed to get a little dirty but I was pushing reference levels. The difference was definitely not night and day, mind you, but I am starting to accept that if I make many cable and interconnect upgrades throughout my chain that the tiny differences along the way will add up to produce a more profound, noticeable effect.
Which brings me to my next task. Choosing proper incoming and outgoing ICs for use with the Mapletree Line 2A Tube Pre that I will most likely snag from Face next week. Then I will want to upgrade the speaker cables going from my XPA3 to the Electromotions. Can anyone give suggestions for such cabling? Not looking to spend hundreds, just looking for something better than stock, something that will give a noticeable improvement in sound.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
    F1nut Posts: 52,022
    edited May 2014
    You are welcome to sign up for the MIT cable demo program.
    BTW, what you are hearing is the result of a lower noise floor.
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2014
    Cleaner signal=lower noise=more space around notes. That seems reasonable to believe.
    How do I sign up for the cable demo program? Although I'm not sure I can afford MITs.
    Edit: Who is Doug and what kind of cables does he have?
    F1nut Posts: 52,022
    edited May 2014
    Sticky at the top of the page, http://www.polkaudio.com/forums/showthread.php?157156-MIT-StyleLine-Cable-Demo-Review-Round-5-USA
  • Hermitism
    Hermitism Posts: 4,338
    edited May 2014
    ROHfan wrote: »
    http://www.douglasconnection.com/
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2014
    Yeah, not gonna go with Doug. His IC's run four figures.
    gudnoyez Posts: 8,174
    edited May 2014
    I was fortunate enough to get some MITs speaker cables from George Daniels got the matching ICs off E-Bay best $250 I ever spent, I also got a Pair of Signal Speaker Cables a Center Channel Cable, and 5 Signal Ultra ICs off the forum paid $200 so I have got some pretty good deals off the flea market.
    I think the Signal Ultras might be up your alley for what they go for, you should also sign up for the MIT samples that Jesse is sponsoring, you might as well try them out.
  • Hermitism
    edited May 2014
  • polrbehr
    polrbehr Posts: 2,852
    edited May 2014
    Given that the gear you've put together already sounds damn fine as is, I figured you'd have nothing to lose by swapping in a new cable; my interpretations of my own system were very similar to yours after I upgraded too.
    Next time we meet up I will let you try a Signal Cable Magic Power, also a Xindak digital cable if you want. I also have a couple different ICs you can test out. And no worries on the time, these are spares not currently in use for me.
    And take the advice and try out the MITs, they are worth the effort to get your ears on them.
  • kve777
    kve777 Posts: 10
    edited June 2014
    Yes, get in on RoadShows to try different IC's. It's worth the time to find the ones that are right for you.
  • Upstatemax
    Upstatemax Posts: 2,815
    edited June 2014
