VR3 comes through again x-overs in
leftwinger57
I was really hesistant to post this but Trey said go for it so here's the story. First of all I was a putz in not grasping that the new modern caps and resistors would make such an obvious difference. I bothered Trey for months on end and I don't have to tell you guys that finances will factor in everything I do concerning these speakers. We finally agreed on a fairly standard x-over conversion with using my boards. I did manage to mangle some of the harnesses doing the retro work for the Neutrik fittings and he provided new harnesses to go the terminal cups and the Neutrik connector. Now the heartache, he sends them out and were supposed to be at my door Friday by Fed-EX and NEVER come. I'm freaking now knowing it's a holiday weekend and tracing this box would be impossible. Today at about 6am there's a loud knocking at my door and a Mexican woman says they dropped this off at my house but it may belong to you. It sure did. Holy sh$t an honest person and then I got to work. It baffeles my mind that a guy like Mr Polk could not devise a better way of securing the x-overs w/ these little standoffs just a bit out of reach and a freaking hassel. That of course took most of the time. I plugged in the coil leads, the harness to the drivers and to the tweeters on the other side. I did button them up before hearing them as it was still to early to play them. Finally my neighbors leave I put on Mark Knofler Sailing To Philadelphia and it was like being in the recording studio right next to the board and the monitors. I'm not one w/ the tech terms all I know it sounds way better than before by being so much clearer, the highs w/ the 194s coming through beautifully and then I put on some albums and they are wonderful. This is bliss and it all turned out ok in the end. That's it for these 2Bs I have done all I will do. Again many thanks to Trey, VR3-MODS for having to deal w/ not the brightest bulb in the box but he worked me through every process and all I can do is give a word of mouth recomendation ,it's a free country and you can if so inclined do them yourself, go w/ anybody else I went with VR-3 and have no regrets.
leftwinger57 wrote: »I was really hesistant to post this but Trey said go for it so here's the story. First of all I was a putz in not grasping that the new modern caps and resistors would make such an obvious difference. I bothered Trey for months on end and I don't have to tell you guys that finances will factor in everything I do concerning these speakers. We finally agreed on a fairly standard x-over conversion with using my boards. I did manage to mangle some of the harnesses doing the retro work for the Neutrik fittings and he provided new harnesses to go the terminal cups and the Neutrik connector. Now the heartache, he sends them out and were supposed to be at my door Friday by Fed-EX and NEVER come. I'm freaking now knowing it's a holiday weekend and tracing this box would be impossible. Today at about 6am there's a loud knocking at my door and a Mexican woman says they dropped this off at my house but it may belong to you. It sure did. Holy sh$t an honest person and then I got to work. It baffeles my mind that a guy like Mr Polk could not devise a better way of securing the x-overs w/ these little standoffs just a bit out of reach and a freaking hassel. That of course took most of the time. I plugged in the coil leads, the harness to the drivers and to the tweeters on the other side. I did button them up before hearing them as it was still to early to play them. Finally my neighbors leave I put on Mark Knofler Sailing To Philadelphia and it was like being in the recording studio right next to the board and the monitors. I'm not one w/ the tech terms all I know it sounds way better than before by being so much clearer, the highs w/ the 194s coming through beautifully and then I put on some albums and they are wonderful. This is bliss and it all turned out ok in the end. That's it for these 2Bs I have done all I will do. Again many thanks to Trey, VR3-MODS for having to deal w/ not the brightest bulb in the box but he worked me through every process and all I can do is give a word of mouth recomendation ,it's a free country and you can if so inclined do them yourself, go w/ anybody else I went with VR-3 and have no regrets.
Glad it worked out for you. Trey is first class all the way. I hope to get some work from him in the future.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Knofler's Sailing to Philadelphia is incredible! Praire Wedding, El Macho, Speedway at Nazareth to name a few gems.
Congrats on the final product. I'm saving to have VR3 do my M7 and RTA 12 but it might be months away.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
Hey Lew,
It was a pleasure to be of help for you. And I am glad the shipping issue worked its way out!
Remember to crank it up and look forward to the burn in process!
Thank you again!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No, I still like that instant gratification of ss. Also I already admitted I know nothing of biasing what tubes are what value testing tubes, it just seems to much for me. I'm way more into speakers and their design and how each and everyone sound different. I would have thin the heard but if I had a bundle of cash float in I would love a set of Vandersteen 3a sigs, Ohm/Walsh 2xo, maybe try either NHT or ADS. If I had the room I would love to get some ESS Heil AMT 1c pyramids, big footprint but a friend of mine did have them and were spectacular for the time. Lastly maybe Klipsch Forte`. Guys I saved literally for more than a year do to the x-overs because of normal bills, car failures, graduation gifts so if it takes time so be it but it's certainly worth it to extend the life of the speakers you love whatever the model.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Yet another testimony to Trey's extraordinary capability and professionalism -- not to mention exemplary customer care!
Trey and Vr3 Mods can be relied upon to do great work, at reasonable cost and to take care of the customer.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
But not nearly as awesome as you sir!! :P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Let me guess, you left the large inductor in your speakers. There's a bolt on the back panel, you screw it and the whole works come right out.Political Correctness'.........defined
President of Club Polk -
Boy that would be big time suck LMAO if that's what happened. Kind of funny though!! Kind of remindes me of when I decided to apply dynamat to the baskets of my drivers and passive. I covered about every square inch of the baskets. What a dope I was and still am.
Thanks for the feedback on Trey and his excellent work/service. -
F-1 your right and you know your speakers. this inductor was overly slathered in hot glue so I didn't even see the nut and not told in my 1st post I was working basically w one hand tied behind my back w/ a torn rotator cuff that's being scoped and repaired on Thursday. So I wanted them in before the operation, didn't know to remove the coil, and being a bit handicapped just made it that more difficult. I'll ask you this would have been so terrible to extend the coil leads and have the x-overs mounted on the cabinet floors which because of the passive cut out would a hell of a lot easier in the long term.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Treys work and customer service is top shelf. I didn't know how much I was missing till he did the x overs on my Lsi15's!Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun -
Trey is an ace; he has done mods on my LSi9's and my LSIM 703', and both came back and amazed me. His commitment to customer service is only equaled by his technical brilliance.
I just hope he never gets so big that he has to outsource his customer service...
Congrats LW and Keep up the good work Trey!
BTW my LSIM 703's are now at app 350 hours adn just keep getting smoother and sweeter.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Thanks guys!
I will be honest that I have been so busy it has been tough to keep up with some things lately. I am dealing with a few massive scale modifications that have bogged down the proverbial engine if you know what I mean.
You guys rock!
Mike,
I am real happy to hear how those are improving. I knew we had a real winner when I plugged them up! Such good sound from those 703. Maybe one day my schedule will free up to modify my 705?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, your even giving up working on your own speakers to work on other people speakers!
You the man!
Kudos!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I would say you owe Trey a reach around at least. He's dynamite...great guy and anyone looking to do some mods should consult with Trey. Another satisfied customer.
So LW....was it worth it ?HT SYSTEM-
