How can you tell which audio speaker wire is the positive one?
whezz
Both wires are the same bronze color. One wire has letters on it the other one doesn't.
Post edited by whezz on
It doesn't really matter. Just make sure whichever one you you is connected at both ends to red (or positive) and the other to black. Personally if I am using wire that lettering on one of the wires, I use that one as negative.
"Good Sound" by Laura Dearborn. Great book. Try it.
