Kenwood KM-894 amp: common ground or no?
HTguru1982
So I've got an early pair(more on that in a sec) of SDA2's that are being powered by a Kenwood KM-894 amp. For the price I paid, it does a commendable job. So my first question is, is this thing common ground? I believe it was originally meant to be used with a Kenwood pre/intergrated amp. I have been using the speakers without the interconnect cable so whether or not the amp was common ground was of little importance. But I just finished making my own cable using insulated alligator clips but before I hook it up, I want to make sure I have a common ground amp. Here is a link to the manual: http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/km894.pdf
My SDA2's are an early set with the funky connector as seen in the pic. So my second question is, and I think I pretty much have the answer but want to be absolutely sure. Is this the correct way to connect the interconnect cable: Pin 1 on left speaker to Pin 2 on right speaker?
Thanks in advance!
Thanks in advance!
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
Read this. Also, don't be afraid to search the forums. Good luck!
http://www.polkaudio.com/forums/showthread.php?152902-Common-ground-amps&highlight=CHECK+COMMON+GROUND2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Got a multimeter last night and turns out the amp is indeed common ground. Thanks.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Subwoofer: SVS PB10-ISD -
No problem. I'm glad I could help.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
