Dr. Spec???
dholmes
dholmes Posts: 1,136
Where is the Dr.? I want his thoughts on my sub idea!
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited February 2004
    First of all, what is 'base'? A small platform? Are we talking baseball?
    Second, not sure where the good Doc is, but why don't you make a few MORE new posts - then he might magically appear.
  • dholmes
    Easy, cant spppeelll got kick in the head by a mule when I was a kid.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    I think if you build a sub you should follow tried and true methods described by others. Infinite baffle, acoustic suspension, vented. I think your idea might provide questionable or unsatisfactory results. I try not to reinvent the wheel when it comes to bass.
    My next project will be a dipole sub for an upstairs 2 channel rig. Won't cost much to build and it will be cool. Will be using the Adire dipole drivers - really sharp looking.
    SVS
  • phoneisbusy
    phoneisbusy Posts: 867
    I checked out the Adire site once. The dipole driver with passive radiator reference design looked sweet. Doc, any pointers to a site to interpret what the various F3, F8,... numbers mean?
    Pretty broke at the moment but hopefully by the time I understand this stuff... ;)
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • gatemplin
    gatemplin Posts: 1,595
    Here are some quick definitions of some T/S spec: http://www.mmxpress.com/technical/terms.htm
    A good book is The Loudspeaker Design Cookbook by Vance Dickason and another website is www.diysubwoofers.org
    Hope this helps Dave
    Graham
  • Dr. Spec
    http://www.linkwitzlab.com/woofer.htm
    Something along these lines, but in a nice wood finish. It should get to 40 Hz in a small room, with unparalleled SQ. Thinking about pairing the dipole up with some of those $500 Maggies and my high current h/k 870 amp for a cool 2 channel music rig.
    Doc
    SVS
  • PPuleo
    PPuleo Posts: 9
    I'm looking for help. My home system is on the showcase. I'm working a 303 sub off of my RTI8 mains with a Csi3 and RTi4's in the back. Currently, I also have a 202 working with the 4's in the back, sounds pretty good, but some feedback suggested "stacking" the 202 with the 303. How do you stack ???, Other feedback, suggested I would be better without the 202 on line, others said ask Dr. Spec. Overall my bass response is good, but we all want better. Any thoughts on the 202 utilization. Thanks.......
  • goingganzo
    goingganzo Posts: 2,793
    use your sub out and run it to the 2 subs and set all speakers to small. and set subs next to each other or one on top of the other.
  • Tour2ma
    Tour2ma Posts: 10,177
    I think you will like them alot. But were it to work out that a pair of 1.5's or 1.6's were around, for only a couple hundred more you'd be extra wowed...
    I assume you have heard Maggies.
    More later,
    Tour...
    Vox Copuli
  • Dr. Spec
    No, that's why I want a pair. They have a new model for only $300/pr. That's a pretty small risk. It's getting pretty rave reviews over at AVS. I'm sure they won't disappoint......
    SVS
