Tubes...where to begin??
ROHfan
ROHfan Posts: 1,014
edited May 2014 in 2 Channel Audio
The deeper I get into the audio rabbit hole the more I start paying attention to the folks who talk about tubes and their importance in the chain.
It was suggested in another thread that I might consider a tube pre. Considering the the speakers/amp/AVR are pulling double duty for music/movies I was wondering if the sound would benefit noticeably using a tube pre with HT bypass. Then I started reading up a little bit about tube buffers and read through the thread by inspiredsports and I'm beginning to think I should give tubes a try. The question is, will a tube buffer be a good upgrade? Or should I go with a tube pre with HT pass-through? I should state that I have no intention to start a dedicated 2 channel setup so whatever I get has to fit into a HT setup.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • thsmith
    thsmith Posts: 6,082
    edited May 2014
    IMO if you are not going to use it for 2 channel I would not go there. A Tube buffer in your case just add more circuits and not really improve your sound, change yes but not likely to improve.
    YMMV
    mhardy6647 Posts: 35,209
    edited May 2014
    I would agree; from my perspectives the tube buffers exploit vacuum tubes for all of the wrong reasons.
    My insanely biased advice (FWIW):
    Get a nice little push-pull EL84 stereo integrated amplifier (vintage or modern, production or DIY) and pair it with appropriate loudspeakers (fairly sensitive speakers are required; push-pull EL84 is good for about 14 watts per channel)... or, alternatively, get a very good, straightforward stereo "linestage" (active line level preamplifier) and use it with whatever power amp and speakers you wish.
    Another alternative could be a vacuum tube headphone amplifier, if you have any serious interest in headphone listening.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2014
    If I'm reading correctly you say you don't want a DEDICATED 2 channel setup, which to me is saying you would like to have a 2 channel system within the confines of your current system and not a seperate, stand alone 2 channel system. If this is the case then I definitely recommend going with a tube pre with ht pass through. This will give you much better results than a tube buffer. I would find an Anthem Pre 2L and be done with it.
  • Face
    Face Posts: 14,340
    edited May 2014
    Another vote for a tube pre with HT Bypass. Most tube buffers are band aids and aren't of the same quality as a good tube pre.
    edited May 2014
    that works for me... whatever a "HT bypass" is... ;-)
  • Face
    Face Posts: 14,340
    edited May 2014
    Due to it being a HT/2 channel rig, a small valve amp wouldn't cut it. Besides that, he would need 5 channels. ;)
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2014
    Dawg, you are correct, I haven't the space for a dedicated 2ch rig. How exactly is a tube pre with HT bypass integrated into a HT setup?
  • Dawgfish
    edited May 2014
    It's pretty straight forward actually. Connect the preouts from your front mains on your AVR to the ht bypass inputs on the two channel pre via rca cables. Run the output of the 2 channel pre to the front main inputs of your amp via RCAs. When in ht mode simply have the 2 channel pre set on ht bypass and the signal from the avr will go straight to the amp and to your front mains. Everything will operate with your ht exactly as it does now using the ht remote for volume etc. When you want to listen to two channel use the two channel pre to select your input (CD, SACD, phono, etc.). Of course you will have to connect a source to the 2 channel pre and the 2 channel pre will take over and control the signal going to your amp and front mains. Trust me on this listening to music through a 2 channel pre is night and day better than listening through an AVR, with or without a tube buffer. Adding a 2 channel tube pre to my system was the single best improvement I ever made for listening to music. It really gives you the best of both worlds without compromising your ht or 2 channel system.
    BTW I see your source is an Oppo universal player. Very nice (as is the new rest of your system). You can connect the Oppo to both the AVR and 2 channel pre via HDMI or other digital cable to your AVR and running RCAs from the front main analog outputs of the Oppo to one of the inputs on the 2 channel pre. This would give you a smoking ht and 2 channel setup.
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2014
    Thanks, Dawg. So that type of preamp actually acts like a source selector. Got it. I'm too lazy right now to read up on it but I have to think that the DAC inside the Oppo is better than the one in the Onk so it should work out perfectly. Only question now is...what tube pre to go with? I was offered a Mapletree Line 2A with upgraded caps by another member here. Perhaps that would be a good start.
    Edited to add: Upgdated my sig. No need for the bass shakers anymore now that I have the XS15.
  • Dawgfish
    edited May 2014
    An Anthem Pre 2L would be at the top of the list for a great sounding tube pre with ht bypass that is not going to break the bank (relatively speaking).
  • WLDock
    WLDock Posts: 3,073
    edited May 2014
    I thought all MartinLogan owners lusted after tube preamps and big 200watt SS amp? Lol! I know.....Its not good to generalize. However, I hear they come alive with a nice robust amp. If you have the means...Why not build a hybrid 2 ch/HT bypass system? Go for it!
    If it does not work out.....sell it!
