MIT interconnects causing degradation of high freqs
adam2434
adam2434 Posts: 995
edited May 2014 in 2 Channel Audio
Anyone ever heard of MIT interconnects causing degradation of high freqs due to a failure/change in the cable?
I have been troubleshooting reduced high freq output in one channel, and finally eliminated the issue when I replaced MIT T2 interconnects with a pair of AR interconnects. Makes me wonder if a component in the network box failed/changed, or if there was some other issue with one of the MIT interconnects.
In general, can a cable fail or change to the point that it will reduce high freqs?
5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
Post edited by adam2434 on
    mhardy6647 Posts: 35,253
    edited May 2014
    sure - the simplest explanation for a mere mortal cable made out of wire would be increased capacitance. This will lead to HF rolloff.
    That's not necessarily the "root cause" of the problem you've encountered... but the relationship between capacitance and treble attenuation is well established.
    F1nut Posts: 52,020
    edited May 2014
    Edit: I see it was only one channel, so it would seem you have a bad cable. You can send it back to MIT for repair.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2014
    Passive components can fail as well as active components. Do your cables have switches to allow input impedence selection? If so then try moving the switch a few times to insure it didn't get dirty or somehow switched.
    F1nut Posts: 52,020
    edited May 2014
    The T2's do not have switches.
  • adam2434
    adam2434 Posts: 995
    edited May 2014
    Yeah, just one channel, and when I switch cables on the amp side, the issue follows the cable.
    I've had the T2's for 10+ years, and just recently noticed this. It is fairly subtle, but when I enlisted my wife for some testing, she could clearly hear the difference when I switched cables back and forth between channels, and when I panned left to right with mono recordings.
    F1nut Posts: 52,020
    edited May 2014
    Call MIT tomorrow at 916-625-0129. If you are the original owner they have a lifetime warranty.
  • adam2434
    adam2434 Posts: 995
    edited May 2014
    Thanks, was not aware that they have a lifetime warranty. I am the original owner, though I doubt I kept the receipt this many years.
