center channel advice
et2112
et2112 Posts: 1
edited May 2014 in Speakers
Hello all,
I have come into 4 lsi25's that I would like to use for HT and music and am wondering what my best option would be for a center channel (I can't seem to find the lsic is no longer available anywhere). How would the lsim704c work being an 8 ohm speaker as opposed to the 4 ohm lsi25's? Current speakers (which will move to the office) are rti 2000 front, rti55 rear and infinity center. I am using a sunfire cinema grand 5 channel amp (200w/ch into 8 ohms, 400w/chennel into 4 ohm) and sunfire theater grand II preamp. Any opinions are appreciated.
  • WLDock
    WLDock Posts: 3,073
    edited May 2014
    You can use any center that you like but its just not the best solution. The speakers have different voicing and nominal ohms rating so......
    maybe keep an eye out for a used on on ebay, CL, forums, etc.
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
