SDA 2B Crossover Mod
VR3
Standard mod, you know - space age zip ties that I hand formed from recycled nasa particles, adhesives and tapes that can only be found in a government lab and you know - caps and resistors and stuff...
Post edited by VR3 on
You like the Solens in the signal path?Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis -
They are decent caps. This was chosen to meet a certain price point.
I prefer Clarity Cap.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I think Sonicap would be a good middle of the road (between the Solen and the Clarity)
Have you AB'd these in the past?Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
So, the cost to upgrade my 2B Studios to these are?
TY, TreyAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Same here what are we looking at for studio 2b' s and are CRS+ cross overs much different?Home Theater
The crossovers in your 2B pin/blade SDAs are the exact same ones as in your CRS+ SDAs. When you do them, I'd suggest going with the TL upgrade. It only requires one additional cap and you'd use the RD-0198 tweeters instead of the RD-0194s. -
No "TL" mod Trey??
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Hey Guys,
I have used Sonicap in a few modifications. As a personal preference, I am not a fan of their sound or their build quality. I prefer the cleaner high end response of the Clarity Cap line. I also like how the Clarity Cap line extends to a nicer capacitor like the MR where as Soniseries versus Sonicap with low value bypass caps at crazy prices. Which I think we can all agree that the bypass caps are no good.
This was a modification to meet a certain price point. A top tier 2BTL modification, ESA, Mundorf Mox, Jantzen inductors, EW circuit boards, new binding post plate, new binding post, new SDA cable with nl4 is around $6-700 and that would be a TL upgrade. That is a full rebuild though and we would not need the stock crossovers.
There are many things we can do though at any price point. Our most expensive modification at this point has gone up to $10,000 so the world is your oyster.
This modification runs around the $160 range. Just a budget modification that is short and sweet.
Thank you- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks for the clarification, I imagine bypassing changes the impedance of the circuit for the worst.....Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
It has been proven that bypass capacitors will introduce artifacts.
To me there are many great brands/types out there that are a better choice than Sonicap. Sonicap is a very popular choice though and they are a respectable choice for modifications.
Clarity Cap MR
Duelund
Mundorf Supremes
Auricap
Jupiter
There are a lot of brands that offer far superior products with a wider range of higher end choices.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just out of curiosity, what do you dislike about the build quality of the Sonicaps? Bad materials on the inside, or don't like how they make the leads, or ???
I am not a big fan of the leads, feel cheap to me. I also am not a big fan of the construction in general, they use thin tape on the exterior and they just do not seem to be made as good as the Clarity ESA/SA, Mundorf Supreme variants.
This is just my preference.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
