AkaiMidi System Turntable AP M600
Akai old man
Akai old man Posts: 6
edited May 2014 in 2 Channel Audio
Hi Guys,
My kids now exploring my vinyl collection.
Left hand speaker low volume despite change of plug.
Right speaker output via amp fine
Would it need a new cartridge?
Or is there another fix I haven,t thought of?
Also anyone know the number / type of new cartridge I might need
Many thanks for any advice
Akai old man
Post edited by Akai old man on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited May 2014
    Hello,
    Is the sound balanced from any other source the system has? FM radio for example.
    Regards, Ken
  • Akai old man
    edited May 2014
    Hi Kenneth
    All the other inputs are fine..CD, Tape decks and Tuner
    Seems to be just the Left channel of the Turntable
    Regards
    Ian
  • [Deleted User]
    edited May 2014
    Okay, that isolates it to the turntable and its circuitry. Do you feel comfortable swapping the wires on the back of the cartridge? Or, is your unit a "P" mount where the cartridge attaches to the tone arm in a plug-in arrangement?
    The reason is that, at this point, we don't know if the problem is with the cartridge or the phono circuitry.
  • Akai old man
    edited May 2014
    The reason is that, at this point, we don't know if the problem is with the cartridge or the phono circuitry.[/
    Hi Ken
    It's a P type arrangement
    Slipped it off and found the problem..one of the wires has detached so should be fixed with a soldering job tomorrow.
    You advice is much appreciated.
    I'll let you know how I get on tomorrow as 22.39 hrs here
    Regards
    Ian
  • [Deleted User]
    edited May 2014
    Very good, Ian, I'm glad you found a cause. Let us know how it works out.
    Cheers, Ken
  • Akai old man
    edited May 2014
    All sorted with solder!
    Many thanks Ken
    Regards
    Ian
  • ZLTFUL
    ZLTFUL Posts: 5,657
    edited May 2014
    I had a very similar issue on my Kenwood TT. Glad you got it sorted.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2014
    Yea those little wires will get you everytime
