Travel Trailer
NJPOLKER
NJPOLKER Posts: 3,474
edited May 2014 in The Clubhouse
I am thinking about buying a travel trailer in the future and trying to lay plans on how, what and where to do this.
As usual I have come to you guys for advice. Any RV guy out there? Are there some tings to stay away from or look for?
New or used? I am thinking new. Maybe ordering one custom made to our spec's I guess will be the right thing to do.
A must is a outside or camp kitchen with TV and running water.
Nothing would make me more happy than to hook up the travel trailer to my suburban and go away. No cell phone no laptop no NOTHING. Of course that's impossible since I have children however I am going to do something like that one day.
Post edited by NJPOLKER on
  • codyc1ark
    codyc1ark Posts: 2,532
    edited May 2014
    Mmmmm.... I like your style. I would think your going to have a harder time finding a used one with the outdoor kitchen. Watch out buying new, they'll give a ten year loan on a 20k unit and talk you into writing it off as a second home. I'm currently looking at a few that have been totaled out due to hail. If you know someone who buys from local salvage yards, that is the way to go.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited May 2014
    I think this is the way to go,you can get everything you want.
    Used is always a crap shoot,you don't want to get out to your favorite spot and have unexpected problems.A leak on a cold rainy night can be a buzz kill.
    Just my two cents.
    Dan
  • NJPOLKER
    edited May 2014
    Yeah I hear ya about the outdoor kitchen and buying new. When I buy it it has to be right if you know what I mean.
    The outside kitchen or whatever its called is really the way to go. I plan on making a lot of upgrades to what I decide on. Obviously the sound system will be a challenge.
  • NJPOLKER
    edited May 2014
    Thanks Dan for your thoughts. I HATE a buzz kill
    Maybe I should travel to Indiana and buy one directly from the manufacture.
    txcoastal1 Posts: 13,330
    edited May 2014
    I'm usually the guy who doesn't buy extended warranty etc. but one of my employees purchased a lightly used RV for work and play with additional insurance/warranty and saved him a bundle as the little component crap in an RV is expensive to replace. They even warranty serviced the RV as he was out of town on vacation done onsite.
    EndersShadow Posts: 17,596
    edited May 2014
    There's more than corn............................. in Indiana...................................
    Lots of RV places out here lol.... probably because us Hoosiers want to escape the CORN!
  • polk500
    polk500 Posts: 1,171
    edited May 2014
    Well as an avid camper and having own a few. Make sure your haul vehicle is up to the task as the salesman will almost always try and convince you to buy the biggest unit possible. Good for them more money bad for you if your SUV is pushed to the max trying to tow. I suggest finding out the max towing cap. And staying 20% under or you find thAt your SUV is overheating or transmission goes.
    But other then that it's an blast.
    We're going on our first trip of the year this weekend.
    Cheers
    Roger
  • Oldfatdogs
    edited May 2014
    Man I speak from experience,a couple years ago I went with my Brother inlaw for our Bdays to the coast in January.It started raining at about 10:00 pm and here came the leak,so out in it we went with the tarps and bungee cords and rope.It took a while to get the head just right again.:mrgreen:
  • amb426amb1
    amb426amb1 Posts: 148
    edited May 2014
    I'm going to reiterate what Polk 500 said. I quickly went from trying to pull with gas to pulling with diesel. Not sure if you have plans to pull long distances, but it can be unsettling when the load pushes the tow vehicle. I sold my 5th wheel rig and now have a motorized rig but pull large car trailers on a regular basis. Camping Is a great recreation... if your into maintenance but the family time is irreplaceable.
  • dkfreebird
    dkfreebird Posts: 1,186
    edited May 2014
    I agree with the last two post,I bought to heavy for my first tow vehicle,had to upgrade.Now I think I will just go to a motorized because the gas mileage is about the same by the time you pull that much weight with a gas vehicle
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
  • amb426amb1
    edited May 2014
    dkfreebird wrote: »
    That is the other advantage of diesel rigs...if the cost of diesel is reasonable, they kill gas pulling for MPG and have a service life of 2 or 3 gas engines.
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited May 2014
    The tow vehicle is VERY important as others have said. A 5th wheel is the best way to go for a trailer. Much easier to control in almost any situation, and the weight on the hitch is very close to the rear axle of the truck. Don't go with the cheapest manufacturer. DO look for a EPDM roof on whatever you buy. EPDM is a roofing material that will last many years, and unless the roof is damaged, you shouldn't have any leak problems. A metal roof, is more prone to leaking. With any roof though, all the stuff on top needs to be resealed occasionally. Hatches, vents, AC, all go through the roof and the sealant will deteriorate over time, so needs to be checked every year. Get the largest water heater you can. You'll thank me later. Get Carrier AC or Carrier AC/Heat (heat pump) unit. Since you are more than likely going to order a new one, opt for the best quality options. You do get what you pay for.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
