Which?
Mikey081057
Mikey081057 Posts: 7,127
edited May 2014 in Electronics
Deoxit product (spray) works best for cleaning potentiometers?
Hard to tell from the literature.
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
    edited May 2014
    Deoxit Gold....what piece are you referring to ? Different potentiometers are harder to clean than others.
  • Mikey081057
    edited May 2014
    The Marantz 2385 Volume pot, and it is a **** to get at.... would love to take it out ad clean/rebuild it but I don't want to F it up... I tried cleaning it with some Deoxit fader spray and it is better but I can still get an occasional noise out of it. Gonna order me some GOLD
    edited May 2014
    Not familiar personally with that specific pot but I know a lot of those old ones are hard to get at. You should see some holes on or near the bottom to spray the Deoxit into. Don't forget to let dry out good before powering up again.
    pitdogg2 Posts: 27,557
    edited May 2014
    or try the 100% solution with the needle. Spray is only 5% solution...
