Amp for MM465 and MM120
Systems
I'm looking for at a few four channel amps. I plan on using the front two channels to power the 6.5 components and bridging the rear two channels to power the 12" sub.
Here are the amps I'm looking at so far:
(4ohm front config, and 4ohm bridged rear config)
PPI 4400.2
50 x 2 + 200 x 1
Orion Xtreme 500.4
62.5 x 2 + 250 x 1
a/d/s (forgot the model)
50 x 2 + 200 x 1
I know the power levels are on the low side, but that's my budget right now and I don't want a low quality amp. Would any of these amps suffice? Any suggestions for other amps in that price range? Thanks.
PPI 4400.2
50 x 2 + 200 x 1
Orion Xtreme 500.4
62.5 x 2 + 250 x 1
50 x 2 + 200 x 1
Testing
Testing
Testing
Testing
Testing
