SDA 1c , I took the plunge but need some advice .
Dropthebeat
So I was able to snag a pair of sda 1c for 200 dollars .... I couldn't pass it up as I've always wanted a pair of of these. Well I popped out all the dust caps and took them apart amd found that one of the passives had unglued itself from the ,what I believe is called the spider , correct me If I'm wrong . Now what would be the best way to go about gluing that back together. ?
Question number 2. The guy that sold them to me said the tweeters ha stopped working on one of the speakers but when I listened to them they're working fine , should I go ahead and remove the poly switch ? Or could it be something else ?
Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Sda 1c - my new favorite speakers
Rta 8,11tl,15tl
Monitor 10 and 12
Marty sub 18" still in the works
Klipsch sw12-2
Hobbies turn into addictions .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Oh and their is a good sized dent on one of the corners on the top of the speaker, I'm guessing a replacement top would be the best way to go about fixing that ?Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Hobbies turn into addictions . -
Congrats! That's great price.
Where you located at?
1. Wait for others to answers but I think you can just glue it back as there is no magnet/VC to worry about.
2. Take the bad tweeter out and check it with a multi meter if you have it. If not swap that tweeter to another one and see if it works. If it does, it could be the poly switch that needs replacement or replace with .3-.5 resistor.
For corner dent, replacement is the right way to go as even wood fillers need quite some work to match. Or you can take it out and put the dented side towards the back so it's less noticeable.
All the tweeters are actually working though , he had told me they stopped working but when I went to pick them up they were working fine. . I'm in denton Texas about 30 min north of Dallas .Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Haha I think for the moment I'll probably put the dented side to the back , genius !!!!!Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Congratulations. That's a great deal on fine vintage Polks!
Whether or not the stock tweeters are working (assuming they are the stock SL2000s), I suggest you replace them with RDO194s from Polk Audio. You'll love the improvement in sound quality IMHO.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Yes they're still the original tweeters , I bought the speakers from the original owner , he even gave me the boxes . . Thanks I've been lurking all over Craigslist waiting for a good opportunity and it finally paid off . Really excited to get them going this evening when I get home .Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Would like to hear how they compare against RTA-11T and 15TL.
Do not use epoxy as it will melt the Styrofoam. IIRC, some have used Aleene's Tacky Glue. An acrylic bonding agent would work as well.should I go ahead and remove the poly switch ?
Yes and replace them with either a jumper or a .5 ohm resistor.Oh and their is a good sized dent on one of the corners on the top of the speaker, I'm guessing a replacement top would be the best way to go about fixing that ?
That type of damage can be repaired by a professional so that you can't even see it.Or you can take it out and put the dented side towards the back so it's less noticeable.
You cannot turn an end cap so that the front faces the back. -
Yeah these sda will be my summer project before I get back to school , I want to restore them and get them in tip top shape . I didn't think about getting the top professionally fixed I was just going to replace it but I'll definitely have to look into that . The top is really the only thing bugging me about these speakers . It did have sunken dust caps but I managed to pull them out and I applied some water on the caps with a brush ( don't know if I shouldn't have done that ) anyways this morning I took a look at the dust caps to see if the crease marks disappeared and bam they look good as new .Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
I have yet to listen to give the sda a good listening but when I do I'll post my opinions on this thread ... I'm sure someone more inclined in this area could give a better review but regardless I'll post my experience on here when I give the sda a good audition.Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Sorry to interrupt this discussion you appear to be having with yourself, DTB! ;-)
Just kidding...
Congrats on getting into the SDA world! I think you'll find the wait for the right opportunity was well worth while and I hope you find it a very enjoyable experience.
Buuuuuuutttt....as is often said around here...pics, or it didn't happen!
Looking forward to hearing your impressions once you get the chance to listen to them for a while. -
Haha talking to myself is therapeutic , I'll post pics when I get home . And thanks F1 , I'll be replacing the poly with a jumper and then a resistor to see which one I prefer. Thanks everyone And sorry about the rumblings . Can't seem to come down off this sda
High.Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Yea I wanna see how big that dent is pictures please :-)POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Congratulations, dtb, and welcome to the SDA family!
I'd be calling in sick for the rest of the day just to go home and "listen"Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Congrats on the find DTB, welcome in to the SDA family and CP!
Congrats on the SDA's & at a great price. Just curious how you have them set up-placement & did you get the cord (not sure if i missed that) . R & L speaker in placement properly. Im looking forward to hearing your thoughts of those compare to your other fine speakers you have. EnjoyRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Well yesterday I didn't get home until late so I didn't even get to listen to them. . It's killing me not being able to listen to them yet . Here are some photos thoughYamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
That corner took a big hit. I would open that speaker to inspect for cabinet damage such as open seams and check that the crossover is still attached to the inductor.
A good shop would be able to repair the corner, but it won't be cheap. -
boston1450 wrote: »Congrats on the SDA's & at a great price. Just curious how you have them set up-placement & did you get the cord (not sure if i missed that) . R & L speaker in placement properly. Im looking forward to hearing your thoughts of those compare to your other fine speakers you have. Enjoy
Well I have them in my bedroom which is too small to place properly , I'm in the process of moving into a different place so I'll soon have an extra room for my speakers . And yeah the previous owner still had the cord and boxes and manual.Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Yeah I opened them up and checked all the drivers , the crossover of course wasn't attached to the inductor but I believe that was because the previous owner had taken it off to see why the tweeters weren't working ... The previous owner told me he bought the speaker at a marked down price because of the dent do that dent has been there for quite some time .Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
Your lucky the magnets didn't move.
After you get settled you can fix that you still got a very good deal!POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Other that the bumped corner, the speakers look very clean from your pics. Do you think the speaker got knocked over and that's how the cornered got damaged?
Thanks , the speakers are in great shape that top just kills me , I'll have to get a quote on how much it's going to cost me to have it fixed . . I'm not sure how it got damaged but the original owner told me he bought them new like that from a retailer at a discounted price .Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Rta 8,11tl,15tl
Monitor 10 and 12
Klipsch sw12-2
That worked out for you too
look very nice. Randy-Maine
by David WMG
