Adcom 5802 after warm up
acmf74
acmf74 Posts: 937
edited May 2014 in 2 Channel Audio
Folks...
I use my 5802 for HT and 2Ch music. As of recently, after it warms up I hear a "humming" coming from the amp but its not audible through the speakers. I suspect something may be going on it/needs repair.
Ironically the music and HT sound fine.
Anyone have a similar experience?
tia
Post edited by acmf74 on
  • bthogan
    bthogan Posts: 151
    edited May 2014
    I've had it with my McCormack. Intermittent. Seems to be related to bad wiring in my apartment. Could also be transformer lamination, as Kim says. You should take a look at this thread:
    http://www.polkaudio.com/forums/showthread.php?160855-B-amp-K-monoblocks-humming
    Starts off talking about buzz through speakers, meanders over to useful discussion re: amplifier (transformer) hum and fixes.
    This might help too (from the linked thread):
    http://www.diyaudio.com/forums/solid-state/2080-dc-filter.html
    Not sure about the DIY (above my pay grade), but some good explanations.
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • Blownrx7
    Blownrx7 Posts: 137
    edited May 2014
    All excellent sugestions as to the noise source. If it comes and goes, it probably is the power transformer responding to noise on the power lines. Any flourescent lights on or dimmers nearby? Did the refrigerator or A/C just kick on?
    If the amp just has to be on and the noise is always there at pretty much the same level, I would check for cold solder joints in the power supply section - especially around the rectifier diodes.
    hth
