B&K monoblocks humming
audiocr381ve
audiocr381ve Posts: 2,588
edited May 2014 in 2 Channel Audio
I have a pair of B&K M200 monoblocks that have been sitting in the closet for awhile as I was on the hunt for a nice stereo rack (wife didn't want them on the floor, totally understandable). In the meantime I was using my trusty Parasound HCA-750a on a little table stand and was getting zero hum from my Totem Hawks. Well I found a rack and it was time to bring back the big monoblocks. They really do sound fantastic and smooth, but I'm getting some hum that's audible from several feet away. At my listening position, I can hear it if I try.
I'm not sure if there is a problem or not, but my guess is that these old amps just hum and that's that. If that's just the way it is, I'm not sure if I want to live with that. I'm just to OCD to have hum in my system.
OR
Do you think there is a problem? I have a guy in town who's supposedly a great tech who may be able to work on them.
Thanks gents
Post edited by audiocr381ve on
    edited May 2014
    Did ya try lifting the ground ? Try the easiest things first before trucking off to the repair shop. Btw- I'm also OCD when it comes to hums/buzzs/ground loops....I'd rip the whole thing apart to find it. Fortunately right now, mine is as quiet as a church mouse.
  • audiocr381ve
    edited May 2014
    tonyb wrote: »
    I forget, do I lift the ground by using a cheat plug? I'm running the amps into an APC H15 power conditioner. I'm absolutely sure it's the amps since the Parasound didn't make any noise.
    edited May 2014
    Yeah...for the 2 bucks a plug, worth a shot.
  • audiocr381ve
    edited May 2014
    tonyb wrote: »
    Cool, will give it a shot. Thanks Tony
    edited May 2014
    I guess I should have asked prior to suggesting the cheater plugs....the hum is coming threw the speakers right ? It's not a hum from the amps themselves ?
  • audiocr381ve
    edited May 2014
    tonyb wrote: »
    Yep, through the speakers only.
    edited May 2014
    Good, then most likely a ground loop issue. Just wanted to make sure, hate to give out the wrong advice. Well, it is kinda entertaining for those on your bozo list but not guys I like.
    F1nut Posts: 52,104
    edited May 2014
    Don't do that, plug them straight into the outlet.
  • chumlie
    chumlie Posts: 8,658
    edited May 2014
    f1nut wrote: »
    don't do that, plug them straight into the outlet.
    this !!!!
  • unc2701
    unc2701 Posts: 3,587
    edited May 2014
    Quick way to test for ground loop w/o having to go out & buy the cheater plug: grab a spare speaker wire and put it on bare metal on the chassis of the amp and bare metal on the chassis of the preamp. If the hum goes down/disappears as soon as they're connected, you've got ground loop.
    Backburner:Krell KAV-300i
  • unc2701
    edited May 2014
    BTW, for completeness, transformer mechanical hum coming from the body of the amp (not through the speakers) is usually caused by DC on your AC line and can be solved by getting a PS Audio Humbuster or you can DIY one:
    http://www.diyaudio.com/forums/solid-state/2080-dc-filter.html
    Again, not the issue here, but good to know if you ever get the other kind of hum.
  • audiocr381ve
    edited May 2014
    unc2701 wrote: »
    Alrighty, the amps are plugged directly into the wall now. If this trick works, would it be a bad thing to keep the wire connected to both amp and pre?
  • unc2701
    edited May 2014
    Not really- I had some Adcom 565's wired up like that for years. Think of it as treating the symptom instead of the disease.
  • Glen B
    Glen B Posts: 269
    edited May 2014
    Mechanical hum audible across the room sounds like a DC problem. A ground loop will not cause mechanical noise. Emotiva makes a couple of filters that are claimed to eliminate hum from power line DC. I've custom built a few DC blockers.
    Emotiva CMX-2 filter
    cmx2_top_1024x1024.jpg?v=1329518713
    Audiogon Thread - Transformer Hum
    DC_BLOCKER_02_zps4ffff8c4.jpg~original
  • drumminman
    drumminman Posts: 3,396
    edited May 2014
    unc2701 wrote: »
    Or could be differing ground potentials between pieces of equipment (is that the same thing?). I had a terrible hum between coming out of my speakers in the two channel rig that nothing would solve: cheater plugs, unplugging cable and home theater, plugging amp directly into wall, etc. Once I connected the chassis of the linestage with that of the power amp, voila!, silence. All you can hear now is a faint tube hiss if you put your ear on the tweeter.
  • unc2701
    edited May 2014
    drumminman wrote: »
    Same thing as ground loop. Sometimes you do just get a hum no matter what and then the solution is to strap the chassis of the two.
  • BKphoto
    BKphoto Posts: 409
    edited May 2014
    unc2701 wrote: »
    I disagree, your transformer is old and dried out, starting to fail...
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
  • bthogan
    bthogan Posts: 151
    edited May 2014
    BKphoto wrote: »
    What if the hum is intermittent, not constant, and not apparently related to load (i.e. music playing and/or volume)? Honest question. My amp's transformer hums now and then (there's no similar buzz or hum through speakers). The transformer is a relateively new Plitron. Other appliances also hum now and then (e.g. refrigerator). It sounds like it's DC on my AC, which would still be a drag (Humbuster isn't cheap), but a new transformer would be more of a hassle ($$$ plus sending amp in for installation).
    Do you think transformer hum is generally a sign of old/failing transformer?
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • unc2701
    edited May 2014
    bthogan wrote: »
    No. DC on your AC is the most likely cause of a hum from a toroidal transformer that's relatively new. I haven't used the $99 emotiva product that Glen links above, but DC blocking is relatively straightforward, so I wouldn't expect the PS Audio humbuster to outperform it.
    I can't speak to BKphoto's experience, but with solid-state gear from the early 90's on, the times that I've encountered mechanical hum from the transformer, it's always been solved with a DC blocker.
  • bthogan
    bthogan Posts: 151
    edited May 2014
    unc2701 wrote: »
    Actually, hadn't noticed that someone had linked to a $99 DC blocker - I just assumed folks were talking about the Humbuster (which I recall being around $300). Thanks for info.
    btw my next audio-neurotic question is, does a DC blocker affect sound, like (e.g.) a line conditioner might? I haven't seen anyone saying it does, so I'll assume it doesn't unless someone says otherwise.
    People seem to agree that the DC noise doesn't really harm the transformer - just causes hum. Is that correct? btw thanks for help.
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • BKphoto
    BKphoto Posts: 409
    edited May 2014
    No way you have DC on your AC line...I've seen many threads from people much smarter than me say thats impossible..
    one that come to mind
    ..." I have never heard that one before. In fact it does not make much sense to me since DC has no frequency it would be completely silent.
    Most buzzing transformers are caused by loose laminations. As the transformers age, due to the heat and constant vibration the varnish eventually breaks down and the transformer core (that is made from lots of thin plates stacked together) gets lose and starts to make noise. Sometimes this can also be caused by the input voltage or output current being too high and saturating the transformer core with excessive magnetic flux...."
    by the way Amazon doesn't even carry the "Humbuster" anymore and i can only find it for sale in UK...
  • bthogan
    bthogan Posts: 151
    edited May 2014
    BKphoto wrote: »
    That may be the problem - I won't pretend to fully understand the science of "DC on the AC", and I've come across credible sources that say that loose lamination can also be a cause of hum. On the other hand, I've also come across a lot of folks who say that Humbuster, or similar devices like the Emotiva thingie, got rid of hum. Doesn't seem subjective - there's a hum, or there isn't.
    Also, I came across this device, which supposedly gets rid of hum that the Emotiva doesn't, and isn't much more expensive. I'm gonna give these folks a call tomorrow.
    http://avahifi.com/index.php?option=com_content&view=article&id=270&Itemid=239
    I'll try to remember to check in when I've got the device, and let y'all know if it works.
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • unc2701
    edited May 2014
    I think the problem here is that BKphoto is thinking of EI transformers, and I believe that bthogan has a DNA-1 with an upgraded toroidal transformer. Delamination and airgaps are a cause of hum in EI transformers, but that isn't the situation here.
    Please see the following, taken from Bryston's site; they down play the effects of DC on toroidal hum since they exclusively use toroidal transformers, but in the last paragraph, the recommend this EXACT solution:
    http://bryston.com/PDF/newsletters/Bryston_Newsletter_V8_5.pdf
    "DC Offset
    All power transformers work with AC. DC (direct cur-
    rent) cannot make the flux changes required to sustain
    a transferable magnetic field. Under normal conditions
    DC does not exist on power lines. However, because
    of nasty things like cheap lighting dimmer switches,
    sometimes a small DC component can occur on an
    AC line. Because toroidal cores are so efficient, they
    sustain magnetic flux easily. DC offset on an AC line
    will eventually cause the toroidal core to go into satu-
    ration by continually driving the core into one direction.
    This sounds bad both literally and figuratively. But, it’s
    rare and there are easy solutions. An EI transformer
    core has unavoidable gaps. These gaps are generally
    bad, both for stray magnetics and for overall efficiency.
    But, they do help here in a passive way. An EI core
    can’t sustain a magnetic field for long and any addi-
    tional flux is sprayed out of its many gaps. So, in the
    rare cases of DC offset, EIs can distribute the addi-
    tional flux into surrounding circuits. Toroids can be
    designed to take DC offset. This is usually only neces-
    sary for extreme applications, like interruptible power
    supplies.
    Another option is to add a simple DC blocking circuit
    on the primary side of the toroid. A few diodes and a
    couple of capacitors easily handle the small amount of
    DC that rarely gets onto AC lines. Many audio compa-
    nies using toroidal transformers employ these simple
    circuits to enjoy the overall benefits of toroids."
    Bryston is known for obsessively eliminating noise in their products (to the point of hand rotating the transformers in every single amp to achieve the lowest possible noise and eliminating a single switch from a product because they found it added some noise), so I trust them over "threads from people much smarter than me".
  • BKphoto
    BKphoto Posts: 409
    edited May 2014
    "the small amount of
    DC that rarely gets onto AC lines...."
    this part stuck out the most...
    have you turned on the amp with nothing at all attached...?
    then take it to another part of the house and plug it in there...?
    I'm probably wrong but I think this is a snake oil thing...
    do you have any LED light bulbs in the room... I've heard that the cheaper brands add noise to the circuit...
  • bthogan
    bthogan Posts: 151
    edited May 2014
    unc2701 wrote: »
    That sounds right; I do have a toroidal. I wasn't even aware that toroidals aren't succeptible to lamination issues - thanks for info. My previous reading made me think that this might be my problem, which would require a bit more than a Humdinger to rectify.
    (In fact, a little more googling has informed me that lamination is among the primary characteristics that differentiate EIs from toroidals.)
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2014
    Glen B wrote: »
    Glen is right. Thought the CMX-2 is discontinued, you can ask Emotiva if they have any old stock left. AVA makes the Humdinger.
    Glen - can your custom single output unit (as shown) be put in front of AC regenerators?
    thanks!
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • User_227675
    User_227675 Posts: 2
    edited May 2014
    I have a pair of B&K M-200 monobloc's... They do not "humm" to much, only a very, very little on silence... Absolutely don't interfere with the music or be herd at normal listening and any volume!... They MUST be used with the quiescent current of output power transistor's in maximum regulated position, in order to work in class A for almost the double than origin!... And MUST be set on to pre-amplifier with balanced XLR connections!...
    On this conditions, they are "warm", yes (and run really hot, it s normal) but the sound is NOT "mellow", but magnificent and beautly POWERFUL, with an absolute and complete CONTROL of bass and are capable of work with ALL types of loads!!
    They are 150 AMPS each!... And power 200 W RMS into 8 ohms, 400 W RMS into 4 ohms and at could keep being used into even low than 1 ohms load with more than 800 W RMS!!!
    For me this is the better quality price combination at the time (almost 25 years ago)... It work very well with the B&K MC-101 Sonata pre-amplifier - mine is the reference first one sending to Portugal by B&K staff for the importer analisys - but i notice that the XLR terminations are not in the comum position with others makers...
    The B&K M-200's could even be upgraded in internal cables and MUST be used with a GOOD and proper main cable (i use Audioquest's).
    My reference interconnect cables are the old's Deltec Black Slinks... With all this, the sound is a dynamic life event in every ways!
  • Glen B
    Glen B Posts: 269
    edited May 2014
    thanks!
    It can go anywhere you want. If the regenerator power transformer is humming, it makes sense to have DC blocking ahead of the unit. I completed one a couple of weeks ago for Audiogon member "Grimace" who wanted a 20A duplex. He is very happy with it (post #32): http://forum.audiogon.com/cgi-bin/fr.pl?aamps&1333477504&openflup&32&4#32
    IMG_0305.jpg~original
