By Request: Response plots on 2.3 - SL2000 vs RDO-194 tweeters
SciFiTom
SciFiTom Posts: 58
edited May 2014 in Vintage Speakers
OldmanSRS requested these, and I was curious, too. Since these are from my listening position, with room reflections, etc., I attempted to (nearly) match yesterday's plot of the 194s, but included a plot from today as the baseline.
Black s/b the 194s, red, the SL-2000s.
Post edited by SciFiTom on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2014
    Design goal met.....
  • OldmanSRS
    OldmanSRS Posts: 419
    edited May 2014
    Thanks for the plot. I would have expected much more difference the way most everyone hates them. I guess there's more to hate than just the response.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • Dennis Gardner
    edited May 2014
    OldmanSRS wrote: »
    I isn't that peak at 12khz that is the issue. It is that the driver goes from being under the new driver from 1-3 kHz to being over it at 12khz. This makes it harsh sounding to some. The 194 is simply better balanced from bottom to top.
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited May 2014
    thank you for the plots, it is differently interesting thank you for posting that
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
  • StantonZ
    StantonZ Posts: 445
    edited May 2014
    Good stuff!
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • SciFiTom
    SciFiTom Posts: 58
    edited May 2014
    Excellent point Mr. Gardner. I hadn't considered the matter from the perspective of the overall slope.
  • Face
    Face Posts: 14,340
    edited May 2014
    What distance were these measured from?
    Distortion measurements may tell us more than just FR.
  • SciFiTom
    SciFiTom Posts: 58
    edited May 2014
    Face,
    these plots are from my listening position, so the distance is about 15 Ft.
    I've moved on from the tweeters discussed in this post to the TL XO (tweeters only) and 198s. While I left the stock XO in place, so I could revert if needed, I'd really rather not return to the scene of that crime. I think this post already says all I wanted to say about the other tweeters.
  • Face
    Face Posts: 14,340
    edited May 2014
    If you want a clean measurement of the tweeters, try from only 3' away. At 15', you're measuring the speaker and how it interacts with the room.
  • SciFiTom
    SciFiTom Posts: 58
    edited May 2014
    The standard is 1 meter, and then I'd have to at least drag them outside, since I don't know of any anechoic chambers in the area in the audio range. I was also concerned that 1 meter might be a bit short given the 3 tweeters. Lastly, my ears are usually at 15 Ft. :)
    If I get around to posting what I just did, the picture will improve lots.
  • Face
    Face Posts: 14,340
    edited May 2014
    You don't need to drag them outside, you can play with gating and also place a bass trap on the floor between the speaker and mic. You can also increase the distance to 2M to allow better driver summing.
  • SciFiTom
    SciFiTom Posts: 58
    edited May 2014
    Face wrote: »
    Truth, though I don't have bass traps at the moment. I do use a 4x6Ft. panel of HF absorbers on the outside of each speaker - about 4Ft. away, but the room is almost 800 sq.Ft. without a wall on the right side of the speaker locations, other than the skinny stuff mounting the foam panels (Auralex 2in. wedges), and vaulted ceilings going the wrong way. I've only got the OmniMic2 from Dayton Audio, and I haven't found a gating control. It seems like it's kind 'a running open loop depending on the DVD, rather than some sort of tracking sweep generator. The 15 Ft. bit is why I only provided comparative measurements.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2014
    Those plots are exactly how i would expect them to look, not enough from 1k-4k and to much above 10k especially at 12k.
    That is why I have replaced all of mine with 194's.
