Will Tweeter from Mini Monitor work in 7s or 10s
OldSchoolPolk
Hello all.
Checking to see if the tweeters in a Mini Monitor will work in a pair of 7s or 10s or 12s.
I know there are diff versions (Series) but I did not know if they would work with the c/o in the other models.
Thanks!
Thanks!
HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
Post edited by OldSchoolPolk on
My mini monitors have Peerless tweeters in them. If your 7 or 10's are early models that had the peerless from the factory- then yes you can use them. If they had the SL2000 then the crossover is different and would not be an exact match.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
