Turning components on-off question
laotzu61
My normal turn on, turn off sequence is cd player, preamp, amp on; then amp, preamp, cd player off. With a tube buffer hooked up to the cd player, should I turn on the cd player, then the tube buffer before the preamp, and reverse the same when turning off; or the tube buffer first, then the cd player, etc? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
I'm fairly certain the only concern is Amp on Last . . . . Amp off First . . . the others do not matter
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
^^^ I'd go along with this ^^^
