Recognizing flacs on my receiver
Easy Runnin
Easy Runnin Posts: 501
edited April 2014 in Going Digital
My receiver is connected to my network and recognizes mp3 and playlists created in wmp11. I wanted to try flac files so I ripped a few and created a playlist with media monkey but my receiver can't see them. I copied the flacs to a flash drive and put it in the USB port on my receiver and it works. So what is going on? How can I get my receiver to recognize flacs and flac playlists on my computer.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited April 2014
    What happens if you convert to wav?
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Easy Runnin
    edited April 2014
    Receiver is an Integra 30.3.
    I ripped a CD as wav files using media monkey. Media monkey shows all 11 songs. Wmp11 only recognizes 4 songs, and my receiver only see the same 4 songs.
    I guess I'm not real clear on what a media server is. It seems wmp11 is my media server and it doesn't recognize FLACs. How do I make media monkey my media server?
  • StantonZ
    StantonZ Posts: 453
    edited April 2014
    I remember there was an "add on" pack for WMP that added codecs for things like FLAC. Search for something like that; it's a very quick install. I can now play FLACs on an old WMP that wouldn't recognize them before the CODEC update.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
