LSIM 704c vs 706c
lostronin
lostronin Posts: 3
edited April 2014 in Speakers
Greetings all!
I'm currently running an all LSi 5 channel set-up off of an Emotiva XPA-5 amp and Yamaha RXV-1700 receiver. Fronts and rears
are LSi-7's and the center is the LSic. The room is 12 x 25 with 10 foot ceilings. I've heard great things about the LSiM 703 and
am awaiting the arrival of a pair to replace my front 7's.
I'm guessing that my LSic will not be a good timbre match for the 703's, so the plan is to order either the LSiM 704c or 706c at
some point. My question is, considering the size of my room and seating position (7 ft. from the front) which of the two would bemy best bet? The 704 can be had for half the price of the 706, and I'll be coming off the LSic, which I've heard is no match for
either of the other two. I'd be interested to hear feedback from anyone who has heard any of the three centers.
Thanks!
  • PSOVLSK
    PSOVLSK Posts: 5,452
    edited April 2014
    706 is way better than the LSiC. I can't comment on the 704 as I've never heard it. The 706 is very big, so check the dimensions and make sure it will fit in your space.
    Sent you a pm.
  • WLDock
    WLDock Posts: 3,073
    edited April 2014
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • lostronin
    lostronin Posts: 3
    edited April 2014
    Thanks for the pm, and tip to check on the size. The 706 is larger than what I can do right now with my space.
