Dreadnougth Interconnect Cable Suggestions
stogie
stogie Posts: 230
edited April 2014 in Vintage Speakers
Which "reasonably priced" cable/wire is recommended for the interconnect? I have read somewhere that DK used Monster Z2 (I believe) in one of his builds, but I can't find that available anywhere. Also I read that MIT cable was used but was very hard to work with. I was thinking any OFC 10-12 gauge speaker cable might work. The SpeakOn NL4FX connectors specs state that the ID of the collar is 14.5mm- so I would say the OD diameter of the wire would have to be around 14mm. Any suggestions would be appreciated. thanks
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
Post edited by stogie on
  • embrown057
    embrown057 Posts: 46
    edited April 2014
    We use a lot of DH Labs T-14 cable and find it outstand in resolution and detail. Might be less expensive alterative to others. http://www.silversonic.com/docs/products/T14.html
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2014
    VR3 Mods (Trey) used Supra Rondo 2x2.5 (13 AWG) speaker wire in two sets of DreadNought interconnects that he built for me. I used Supra power cord in two double runs of power cords that I built. Supra wire, IMHO, is easy to work with, flexible and provides great sound.
  • nspindel
    nspindel Posts: 5,343
    edited April 2014
    I just use Signal Cable speaker cables.
  • stogie
    stogie Posts: 230
    edited April 2014
    Thanks for the replies. I will check them out.
    TT: Technics SL-MA1
    F1nut Posts: 51,925
    edited April 2014
    It's not that hard once you learn how to work with it.
    That can be enlarged by removing the rubber collar. If that's still not enough the plastic retainer for the rubber collar can also be removed and if that is still not enough the metal end can be enlarged by using a Dremel with a grinding drum to a maximum of 21mm, which is what I did.
    I highly recommend using speaker cable, preferably the same as you used to hook up your speakers. Interconnect cable or the like should not be used as the SDA cable is basically transmitting the same signals that your amp sends to the speakers.
  • embrown057
    edited April 2014
    Tin plated OFC copper? (TIN) Really? Not my number choice but if that's your choice so be it. Straight high purity 99.xx+ copper either plated with silver or plane is what I find meets any decimating ear's pleasure zone. But then again I had people tell me there's no difference from ZIP cord either.
