Amp Re-Cap Break-in
Faustin
Faustin Posts: 1,151
edited April 2014 in Electronics
Just had an Adcom 555 amp re-capped. Is there a burn-in period similar to re-capping a speaker crossover?? On the same note... I just purchased a Marantz CD player. Will that have a burn-in period also?? Thanks for the input.
Post edited by Faustin on
  • FTGV
    FTGV Posts: 3,650
    edited April 2014
    Faustin wrote: »
    Just had an Adcom 555 amp re-capped. Is there a burn-in period ...
    No..with electrolytics just the slow deterioration process starts take place.Give it 20 ish years depending on temp lifespan rating of the caps and the actual operating temp.
    F1nut Posts: 52,154
    edited April 2014
    Absolutely yes to both.
  • skrol
    skrol Posts: 3,480
    edited April 2014
    When I re-capped my Parasound the burn in seemed rather dramatic. The sound started harsh and lacked dimension. Over the course of just a few hours, you could hear it smooth out and the sound stage open up.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,154
    edited April 2014
    The last amp I recapped wasn't anywhere close to 20 years old and had no problems with the original caps. The owner wanted better quality caps installed. After the owner got it back he wasn't happy with the sound and commented about the lack of bass. He thought he made a big mistake. I told him to give it some time, which he did. Reported back that it sounded better than ever and that the bass was tighter, cleaner and more powerful than before. Yes Virginia, burn in is real.
  • Faustin
    edited April 2014
    Thanks for the input. I will give them both some time to break in and see if I can notice a difference.
