LCD TV screen cleaner recommendations
jflail2
jflail2 Posts: 2,868
edited April 2014 in The Clubhouse
I've always just used a dry, lint free cloth to wipe my LCD TV screen off. It appears I managed to put a hand smudge at the bottom of the screen during my last move, so I'm wondering if any of you have a highly recommended LCD cleaner. Is there a specific solution to use or avoid? Is there a certain type of applying tool that works best? Any input would be greatly appreciated, especially on the "don't" side of things.
Post edited by jflail2 on
  • WLDock
    WLDock Posts: 3,073
    edited April 2014
    I use Endust Electronic cleaning spray on everything from the smartphone, tablet, laptop, LCD monitor, to the 73".
  • teekay0007
    teekay0007 Posts: 2,289
    edited April 2014
    jflail2 wrote: »
    Is there a specific solution to use or avoid? Any input would be greatly appreciated, especially on the "don't" side of things.
    DON'T use Windex or anything that has ammonia in it. It will eat into your screen coating leaving permanent damage.
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2014
    Eyeglasses cleaners work great.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • WLDock
    WLDock Posts: 3,073
    edited April 2014
    Yeah, avoid alcohol and ammonia based products. Again, Endust for Electronics has about the largest collection of No Streak, No Static electronic cleaning products...sprays, gels, wipes, dusters, cleaning tools, etc Also, always use a micro-fiber rag:
    http://www.endustforelectronics.com/products.php
    treitz3 Posts: 19,992
    edited April 2014
    Invisible glass.
  • jflail2
    edited April 2014
    Thanks gents. I'll have a look at some of these options today.
  • jflail2
    edited April 2014
    For others looking, I went with the Endust spray gel/ microfiber cloth combo and couldn't be more pleased with the results. Looks like a new TV again! Thanks for the help gents.
