DOA Lsi9
gene stangel
Purchased a pair of LSI9's on ebay and one arrived DOA. Review of crossover board revealed two corner cracked loose. No sound at all even after pushed cracked pieces back into place. Besides negotiating with the seller, any fix recommended or do I need to send it in to Polk?
Gene
Gene
Thanks for the replies. Two corner edges of circuit board were cracked loose. They were still attached but were pushed apart from the main board. One was on the corner where the positive lead attaches to the board. I was able to push them back into place, but didn't do any soldering. Let's just say the packing was pretty shabby although the exterior was undamaged. Maybe a direct hit to one of the terminals caused it. All connections seem to be in place but the speaker is totally dead. If fact my Pioneer sx-1050 would not
click on start-up when connected to this speaker, perhaps indicating a short?
Gene -
Return for a full refund via PayPal.
I was able to get DOA left speaker to working by pushing hard on cracked corner of crossover board, so seller will replace it. However tweeter output from right (non-DOA) speaker is about half of that from the left causing right speaker to sound muddy in comparison. Did multiple tests and swapped tweeters and reduced output level was confirmed. Is this a crossover issue also? No visible damage to board. If it is I will ask for two new ones. or just give up and return them.
Thanks -
This. IMO not worth the hassle with all the back and forth when both speakers have issues.
