Cooler Master Storm Recon mouse and Ceres 400 headphones
jwhitakr
jwhitakr Posts: 568
edited April 2014 in For Sale (FS) Classifieds
I have a couple of gaming peripherals that I just don't use.
1) Like new CM Storm Recon gaming mouse. Only used a few hours, still in perfect condition. Works great for FPS, RTS or other PC game. $25 + shipping
2) Like new CM Storm Ceres 400 gaming headset. I used it for maybe 5 hours to make sure it worked 100%, and have not used it at all since then. Pretty much perfect condition and it works well for all types of PC gaming. $20 + shipping
Recon specs from manufacturer:
•800-4000 dpi resolution Promotes pinpoint accuracy.
•Avago 3090 optical sensor Offers precise tracking and lets you fine-tune the sensitivity and define up to 4 dpi levels for each stored profile.
•1000Hz/ms polling rate Helps ensure optimal performance.
•On-the-fly tuning Lets you switch between multiple USB polling speeds, LOD levels and sensor dpi settings without interrupting your game.
•Mouse wheel With backlight color allows simple operation.
•9 programmable buttons Along with 32KB of on-board memory permit you to store up to 5 profiles and 36 macros for quick access.
•Ambidextrous design Enables comfortable left- or right-handed use.
•Rubberized grip Helps prevent your fingers from slipping.
•3 individual multicolor LED zones With adjustable brightness and color can be fine-tuned or disabled to suit your preferences.
•6.6' cord Provides freedom of motion during use.
•USB connectivity Makes it easy to connect to your existing computer.
Ceres 400 specs from manufacturer:
•Headphone Driver diameter: φ40mm x 7.5 mm(H)
•Frequency range: 20 - 20,000 Hz
•Impedance: 32 Ω
•Sensitivities(@1kHz): 108 dB ± 4 dB
•Input: 100mW
•Connector: 3.5 mm headphone jack
•Inner Ear Cup Diameter: 90 mm
•Cable Length: 2.5m
•Microphone Directivity: Omni-Directional
•Frequency range: 100 – 10,000 Hz
•Signal-to-Noise Ratio: 50dB
•Sensitivities(@1kHz): -30 ± 3 dB (0dB=1V/pa.1KHz)
•Hardware Requirements Audio Usage: Devices with 3.5mm audio jack
•Audio + Microphone Usage: Devices with 3.5mm audio + microphone jack(smartphones)
My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
Post edited by jwhitakr on
  • jwhitakr
    jwhitakr Posts: 568
    edited April 2014
    Bumpage before I send them to hell! (aka ebay)
    My HT
    Amp: Emotiva LPA-1
    Sub: HSU STF-3
