PSW10 or PSW108
s3kshun62
s3kshun62 Posts: 3
edited April 2014 in Speakers
So he title pretty much explains it all. I just picked up the N1 sound bar and these are the recommended subs to use. What is the major differences between the two and which one is worth it?
Post edited by s3kshun62 on
  • Irrenhaus
    Irrenhaus Posts: 1,100
    edited April 2014
    Welcome to the club...
    The only difference I see on the specs is the PSW108 is not available on 220v. All else seems to be the same. You may be able to find the PSW10 cheaper.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • s3kshun62
    s3kshun62 Posts: 3
    edited April 2014
    So safe to assume that the psw108 is just an upgraded version of the psw10? Hope that they both sound great, I'm just replacing an old Instant Home Theater setup I bought about 4 years ago.
