Sundown SAX-125.2
EndersShadow
For Sale is a Sundown 125.2. My Murano has a system that will not allow me to incorporate it or I would try to.
The amp has only ever been presented a 8 ohm load of my Polk db6501's which means its never been over driven or pushed at all.I cannot speak more highly of this amp. The brand is very well known and respected on the competitive car audio circuit. My loss is your gain.
Your package includes the following:
Here is more info on the amp. I will get pics up soon. THE PICS ARE FROM THE WEBSITE, BUT MY AMP LOOKS ALMOST AS MINT
Manufacture page: http://www.sundownaudio.com/index.php/products/discontinued/item/sax-1252.html
Manual here (referencing three channel tri-mode, third diagram): http://www.sundownaudio.com/pdfs/SAX504_1004_1252.pdf
I am asking 150 + shipping from 46268.
Open to offers and again willing to drive to deliver within a reasonable range.
- Amp
- Gain Knob
- Original Box
- Original Manual (I think, if not printed manual)
- Decal
- Memphis amp kit:
- 4 gauge power wire
- 1x2 distribution block (wire 2 amps off the same power wire)
- Ground Wire
- Remote wire
The SAX-125.2 was designed to replace our SAX-100.2 model -- it features an upgraded power supply for a bit more power as well as greatly enhanced crossover flexibility.
This unit was built to satisfy the discerning audiophile who doesn't necessarily want to spend huge sums of money on his full range amplifier. This amplifier utilizes high quality Sanken bipolar output transistors, and 12 of them at that! The SAX-125.2 is also equally suited for subwoofer applications where tremendous power is not called for.
SPECIFICATIONS:
[*]2/1 Channel Bridgeable Class-AB Amplifier
[*]MOSFET PWM Power Supply
[*]Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
[*]12dB Octave Electronic Crossover Slope
[*]Variable Subsonic Filter
[*]High Pass Filter Variable with x 10 Range Selectable Switch
[*]Low Pass Filter Variable with x 10 Range Selectable Switch
[*]HPF/FULL/LPF Selectable Switch
[*]Variable Bass Boost Control
[*]Variable Bass-Boost Frequency Control
[*]Variable Input Level Control
[*]Input Sensitivity : 200mV ~ 6V
[*]Subsonic Filter : 10Hz ~ 500Hz
[*]Signal Input and Line Out RCA Connectors
[*]Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
[*]Tested Voltage & THD: 14.4V & Less than 0.05% THD
[*]Operating Voltage : DC10V~16V Power Input
[*]Wired Remote Controller
[*]MSRP $349 USD
[*]Rated power output (RMS power)
- 4 ohm stereo 125W x 2CH
- 2 ohm stereo 200W x 2CH
- 4 ohm bridged 400W x 1CH
- Signal to Noise Ratio >90dB
- Low pass frequency crossover 50Hz ~ 5KHz
- High Pass Crossover 30Hz ~ 3KHz
- Variable Subsonic Filter 10Hz to 500Hz
- Bass Boost 0~18dB
- Variable Bass-Boost Frequency Control 35Hz to 120Hz
- Frequency Response 10Hz ~ 40KHz (+/-1dB)
- THD@RMS Watts <0.1%
- Channel Separation 75dB
- Fuse Rating 20A x 3
- Input Sensitivity Variable 200mV~6V (+/- 5%)
- Dimensions 252(W) x 58(H) x 340(L)mm
Post edited by EndersShadow on
Bump"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Bump.
Had a couple local bites but no cash in hand so its still around..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Sold.
Wiring kit still available, probably list independently."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Good to hear Dan! I am still waiting to hook everything up!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
