How to buy a used amp/what to look for
payneinthe
payneinthe Posts: 63
edited April 2014 in Electronics
When buying a used amp off CL, what should I be looking for to make sure it's in good condition?
7.1: LSIc, LSI-9 L/R, F/X1000 SL/SR, RM101 BL/BR, PSW 650 SW
Onkyo TX-929
Parasound HCA-1206
2-channel: Parasound P5, Odyssey Kismet, Vandersteen 3A Signature, Pro-Ject Debut Carbon
Post edited by payneinthe on
  • rooftop59
    rooftop59 Posts: 8,120
    edited April 2014
    I would spend at least an hour with it, turn it off and on several times. Unplug and plug in all the cables several times to check for loose connections. Also take a rat shack SPL meter and measure to make sure the outputs are putting out the same volume. This is why I actually prefer to make these kinds of purchases either on this forum or on ebay, because on ebay you have a 45 day inspection period, and you can by a squaretrade warranty. Nothing like that on craigslist...
    Game Room 5.1.4:
    Bedroom 2.1
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited April 2014
    rooftop59 wrote: »
    These are all great ideas, but the few times I've bought sound equipment off of CL, most buyers just weren't too keen on me turning the item on and off, unplugging and plugging back in all the connections and opening the hood etc.I always got the impression they didn't want a stranger hanging out for an hour seeing if anything is wrong with the component . I guess the great thing about buying from someone here at Club Polk in the flea market is that ,if__ something is truly wrong with the item sold(which is pretty rare), it will get straightened out.
  • rooftop59
    edited April 2014
    Polkie2009 wrote: »
    Absolutely agree. Therefore I think the best suggestion to the OP is to be patient (easier said than done I know) and stick around and get to know folks a bit. A good deal is bound to come up in the FM over the summer, so the best advice is to wait for that, or go fleabay as I said...
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 52,105
    edited April 2014
    I would never buy used audio gear off CL. Here and Audiogon, eBay if a had to.
  • badchad
    badchad Posts: 348
    edited April 2014
    I've usually just listened with a brief demo. If it works, I'm good. I've never been keen on hanging out and listening for an extended demo and/or opening equipment to inspect it. I've bought "new" in box speakers off CL and just picked them up without demoing. I'm pretty risk tolerant with CL though. I take my chances.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • skrol
    skrol Posts: 3,474
    edited April 2014
    I would say the first thing is a visual inspection of the exterior to see if there are signs of abuse (spills, busted knobs, busted connectors, etc.).
    Second, turn it on and measure the DC offset at the speaker terminals.
    If it is ok then hook up some speakers and listen for hum or other anomalous noises.
    Then play some music through it and monitor temperature gradients across the heat sinks.
    I looked at a Hafler amp once (CL listing) and saved my speakers (yes, I brought my own) because I checked the DC offset before connecting.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
