Do you know which model this is?
cprest08
cprest08 Posts: 4
edited April 2014 in Vintage Speakers
Hi:
I am trying to find out which model this is. It was bought off of Polk for $120 on clearance in May 2013.
Thanks for your help.Attachment not found.
Polk.jpg 435.5K
Post edited by cprest08 on
  • ZLTFUL
    ZLTFUL Posts: 5,656
    edited April 2014
    Looks *kind of* like the M2 but with a slightly different bezel and newer badge...
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2014
    Hard to tell without another angle, but I am pretty sure its a sat from the RM6750 setup: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290066
    Game Room 5.1.4:
    Bedroom 2.1
  • cprest08
    cprest08 Posts: 4
    edited April 2014
    thanks. It does look like that RM6750. Would these be good rear surround speakers? Or something like R150 or OWM3 be better?
    thanks
  • rooftop59
    edited April 2014
    I would go with the r150 out of those three since it is the only true bookshelf and has the largest range, but it is significantly bigger than the other two so keep that in mind if you are looking to mount. Those 6750s only go down to about 150 hz, so teh sub is going to have to pick up a lot of extra bass. But it depends on a number of other factors. What is the rest of the system made of up?
    Game Room 5.1.4:
    Bedroom 2.1
  • cprest08
    cprest08 Posts: 4
    edited April 2014
    I have for fronts TSx110b and center tsx150c and onkyo powered subwoofer 25hz -150khz.
    i was going for a 7.1 setup and was going to put a pair of owm3 for side speaker on wall becuase of limited space and their mounting options. I do have stands for rear surrounds and won't be mounting them. Is something like rm3300 good or any other suggestions on some decent rear surrounds to go with my setup.
    I also have Denon AVR-E400 receiver.
    thanks
