Picked up some LS90s, rough shape, need replacement drivers
Truls-rohk
Truls-rohk Posts: 14
edited April 2014 in Vintage Speakers
The price was right, FREE
But of course they have some issues. Cosmetically the grills and all front trim and such was in such bad shape I just removed it. Back and Walnut veneer look ok, just some minor scrapes and issues. The cabinets are sound structurally. I'll figure out some sortof covering for the front baffle.
So I fired them up and was pretty pleased to find that they work. Unfortunately it seems that 3 of the MW7100 woofers are toast, and another one has a glue repaired surround (That one also seems to be close to blown by the push test, but does sound clean when playing).
I would therefore like to pick up 4 woofers to split between the pair, and have lurked and read some things here about changing out capacitors, etc. I did already contact POLK here and they were quick to email me back and say they have the mw7010 available at $75, but I don't really have the budget at this point to drop $300. I would even probably be happy with some "temporary" drivers, but wouldn't want to screw anything up either.
I did run across these http://www.mavin.com/store.php/products/super-65-woofer-mid-range-speaker-150-watts-rms-8-ohms-6-12-48-oz-magnet but don't know if they are a real good idea or not, anybody have any experience with them?
I realize it would probably be sub-optimal, but would any proper size speaker of the right impedance (guessing 8 ohms?) work as at least a temporary solution, and if so would you guys have any suggestions or ideas.
I will be keeping an eye out on craigslist too for perhaps other Polk speakers I could salvage from.
Got a little long winded there, Thanks for your help in advance!
Post edited by Truls-rohk on
