tube bias question
laotzu61
laotzu61 Posts: 327
edited April 2014 in Electronics
I would appreciate it if someone could please explain to me what tube bias is, what it does, and hopefully, how I would bias a pair of mullard m8100 tubes for a yaqin cd2 tube buffer. thanks much.
"The symbol is not the reality"
Post edited by laotzu61 on
    pitdogg2 Posts: 27,554
    edited April 2014
    laotzu61 wrote: »
    you do not do that for Yaqin tube buffers. You would buy matched set of tubes for that. To be honest you'd have to have a tube at near end of life to be able to really tell a difference with the CD2 buffer. To bias tube the device will have some sort of screw hole or tool hole to stick something into to adjust a screw to allow for so many milliamps of current to the tube. You do not have that with Yaqins.
    I had two buffers the CD2 and now a CD3 that uses 6sn7 tubes.
  • laotzu61
    laotzu61 Posts: 327
    edited April 2014
    thanks for the info, pittdog2. appreciate it.
  • laotzu61
    laotzu61 Posts: 327
    edited April 2014
    oops! forgot to ask--any sources you may be aware of for finding a matched pair?
    edited April 2014
    laotzu61 wrote: »
    I bought all mine off ebay and I have many left over from my old CD2
    PM me and I'll get with you on some 6ak5 tubes that I have
    Siemens
    Tung sol
    Voshkod
    GE JAN 5654w
    these are some I have.
    Jake(zingo) listed some good places
    F1nut Posts: 52,151
    edited April 2014
    Only power tubes require the bias to be set.
  • laotzu61
    laotzu61 Posts: 327
    edited April 2014
    thanks for the links and other info. i'll p.m. you over the weekend, pitdogg2. I did pick up a matched pair of mullard m8100's, which is what I have in there now. made in England mullards, and they are awesome.
  • erniejade
    erniejade Posts: 6,321
    edited April 2014
    PM pit. Try the Voshkod. You will love them!. The have the same bass as the mullard but, a bit more in the top end and verry musical. Besides pitdogg is a great person to deal with.
  • zingo
    zingo Posts: 11,258
    edited April 2014
    I think many NOS Voskhod tubes are the best for the price.
    edited April 2014
    zingo wrote: »
    to bad they never made any 6sn7 tubes....If you know different I'm all ears
  • laotzu61
    laotzu61 Posts: 327
    edited April 2014
    sent you a pm, pitdogg2.
    heiney9 Posts: 25,580
    edited April 2014
    The Russians did make a close substitute for the 6SN7. If they are anything like the close sub for 6SL7's, you aren't missing much. Not a bad tube but pretty boring compared to it's classic American counterparts.
    edited April 2014
    heiney9 wrote: »
    yep I Know Brock. I was alluding to Voskhod factory as the 6ak5 tubes are pretty darn good. I do not think that factory made any of them though.
