Kenwood KDC-X794 USB/CD/MP3 In Dash Receiver
EndersShadow
Up for sale is my old Kenwood KDC-X794 player from my Jetta. This is a PHENOMENAL player as its bypasses the built in EQ of the iPhone and lets you use its EQ which is MUCH better.
Its got connections for the older 15 pin iPhones and a Aux 3.5mm jack as well for your other players. It does have a CD input. 3 sets of 5 volt pre-outs to be able to run dedicated amps (which I did and it worked great).
The following things are included:
2 DIN converter (so if your current player is 2 slots, this will allow you to convert it to allow space for the player & add an extra slot for holding CD's, etc)
**Note** I cut a slice out of this to allow me to run the Aux & Iphone Wire through it and put those players in the empty DIN slot
Mounting bracket
Wiring harness (which will be setup for a Jetta and will need to be updated to your specific make/model)
15 pin iPhone connector
Remote
6 foot Aux 3.5mm cable
There is a ton of info online about the player so check out some of these sites for more info:
Manufactures site info
Crutchfield
I am asking 75 bucks shipped to CONUS. I am open to offers or trades, but prefer to just liquidate it entirely. PayPal via gift is the preferred method. As anyone who has gotten a package from me will tell you, I pack right so the player should arrive with all parts intact.
I will get some pictures up here in the next couple days as its still installed in my Jetta. For now here are some stock photos from the web.
Mounting bracket
Remote
Crutchfield
Post edited by EndersShadow on
Unfortunately I need an adapter to use this with my stock amp, otherwise I would be all over this.
GLWS!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
bump"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
sold to rooftop (paul)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
