Sda 2btl v crs +tl
geppy1
geppy1 Posts: 3,076
edited March 2014 in Vintage Speakers
If one was to put a pair SDA 2BTLs and a pair of SDA CRS+TLs in a room and compare them what would be the differences one might hear??
Post edited by geppy1 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2014
    DSkip wrote: »
    Deeper bass from the 2 at the expense of the greater transparency of the CRS+.
    ^^^Agreed, there simply isn't any comparison to the soundstages of those separated mid designed SDAs, unless you have a shrunken head and then the side by side mids would sound better I guess.....I don't know, I've always had a big head.
    Toolfan66 Posts: 18,066
    edited March 2014
    Agreed as well. But the CRS+tl's are no slouch in bass either..
  • Dennis Gardner
    edited March 2014
    Toolfan66 wrote: »
    That has to be by design too, the passive facing to the rear actually boosts the bass with wall reflections helping out. Just like pointing your sub box in the trunk of your car to the rear adds a ton of boost over facing into the rear of your back seat.
  • geppy1
    geppy1 Posts: 3,076
    edited March 2014
    What does this mean
    I would assume the CRS sound much bigger then they are?? Morer transparent? Expand on that?
  • nspindel
    nspindel Posts: 5,343
    edited March 2014
    I can tell you that with my TL'ed CRS+'s including the Solen 16mH inductor, there is no lack of bass!
  • Dennis Gardner
    edited March 2014
    geppy1 wrote: »
    What does this mean
    Any SDA models that have the separated drivers like the CRS/SRS lineup have a better soundstage than those models that have the mids placed against each other side by side. This has to do with the width between your ears, according to Polk. The separation of the center of the mids coincide with the space between your ears. That few inches makes the speaker disappear easier and the soundstage presented is wider and more defined at the same time.
