SubWoofer Placement
vscindia
vscindia Posts: 17
edited February 2004 in Speakers
I am placing my SubWoofer right behind my Front Rti8 .
I get the correct bass but not sure if this will cause any problem.
Any responses will be really appreciate..
Vj
Onkyo -Tx-Sr 701
Rti8 L/R
Csi3
Rti4 surround
psw202
Post edited by vscindia on
  • gatemplin
    gatemplin Posts: 1,595
    What could be the problem? If it sounds good to you then leave it there.
    Graham
  • warviper
    warviper Posts: 585
    Try the search feature there are lots of posts on sub placement written by more knowlegeable people than my self.
    Wish I was a polkologist then I could call my self Dr.warviper.
  • warviper
    warviper Posts: 585
    I reread the post. Is your concern the fact that the rti8 are ported right and your not sure if the pressure going back in the port on the speakers? I have some ls90s and I have thought about this also maybe a knowlegable person could respond.
  • pjdami
    pjdami Posts: 1,894
    I would make sure that there is minimum of 3 inches clearance for the ports on both the sub and mains. Subs usually sound the best in a corner but you can experiment here if you have the room. You can use the "subwoofer crawling" method as well. Do a search for this and read up. Also if you have a decibel meter you can run some bass sweeps in different sub placements and check out the response curve. You may have some peaks and nulls in the FR that you can eliminate and get a flatter response. There are some threads on this as well.
    Let us know if you need more help or can't find something.
    P.
  • vscindia
    vscindia Posts: 17
    Thanx for the reply .. Rti'8's are almost more than feet away from the back wall..Sub is 6 inches away from wall but I am planning to hide sub behind my Left Rti8. I was just wondering that Keeping these 2 in close proximity will not cause any damage ..
    Since i am know in this just want to make sure I am doing correct setup.
    Any resposes will be appreciated...
    Onkyo -Tx-Sr 701
    Rti8 L/R
    Csi3
    Rti4 surround
    psw202
  • gatemplin
    You wont cause any damage. Check out this link for more info on speaker placement: http://polkaudio.com/home/faqad/advice.php?article=placement
    Graham
  • vscindia
    vscindia Posts: 17
    Thanx for the help.I am placing my Syb behind my front left Rti8.I just called polk to get more info on the same and they told me not to block Sub completly by front Speaker.
    Another problem for me is my Sub and Front Left speaker are very close to side passage which connect to my other rooms I hope i am not loosing any bass in this process.
    Vj
    Onkyo -Tx-Sr 701
    Rti8 L/R
    Csi3
    Rti4 surround
    psw202
  • PolkThug
    PolkThug Posts: 7,532
    I highly recommend getting an SPL meter from Radio Shack, so you can experiment with placement and get meausured results.
    Regards,
    PolkThug
