Monitor 75T
dbKiller
dbKiller Posts: 316
edited March 2014 in Speakers
Hello all, I have been looking at these for a few weeks, but I haven't really seen any solid reviews. I am curious if anyone has any opinions on these. Are they any different from Monitor 70's other than cosmetics? I do like the full wood grain faces, but also like the looks of the older 70's as well. I appreciate any feedback in advance!
Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
Post edited by dbKiller on
  • dbKiller
    dbKiller Posts: 316
    edited March 2014
    That's what I was hoping for. I know the 70's sound pretty good. Thanks DSkip, can always count on you for some sound advice. Get it??
  • vinyladdict
    vinyladdict Posts: 32
    edited March 2014
    I have had these for about a year now. These things are superb. The high end is amazing on these speakers . The low end is more than adequate for normal music without a sub unless you are a overexagerated low end type of guy. You get 4 6 and a half inch drivers and a dome tweeter and a bass port on the bottom of the tower. . These also work very well on lower powered receivers, I run mine on a Onkyo 50 watt amp and can pretty much peel the paint of the wall at less than half volume. For the price they can't be beat. Look around you should not have to pay much more than $200 a piece for these . I am very satisfied with mine and highly recommend them if you want good sound . Makes my old vinyl sound amazing .
  • Tornado Red
    Tornado Red Posts: 939
    edited March 2014
    +1
    I've had them as the mains in my 7.2 HT for about a year as well, and I'm happy with them too. Most people on here upgrade stuff in their rigs on a regular basis, a common theme seems to be your system is only as good as its weakest link. Everytime I upgrade, I keep by-passing the 75Ts, they never seem to be a priority to replace. I'm sure they will at some point, but the status quo is good for now. I think you'll be happy at this price point if you pick up a pair...
