RTA 8tTL or RT55i
Easy Runnin
Which is the better speaker musically?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
I had 8TL's and they are okay.
From reading the threads, RT55i should be better.
I haven't heard the 8tl's but owned some RT55's for a while. I'd take the Pioneer bookie over them all day long. While they don't dig as deep as the 55, what the Pioneer does bring to the table far outweighs the depth of the 55. If you're running with a sub, then its a moot point anyways.
Not a chance a pio bookie can compete with properly powered 8tls.
