Peerles Tweeters
rmaiers
Were the Peerless tweeters used in the early Monitors and RTAs the same or did some have different electrical characteristics (e.g DCR and impededence)? If so, where can I find the electrical characteristics.
Post edited by rmaiers on
afaik, they were the same although some were Danish and others were made in USA...
someone did a big test/investigation on all the different models try the search....Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Geppy1 did all that
All the same I believe; there were two models though with and without the hole.
I believe the holes were a Polk thing as IIRC Keith said Polk did it for venting the voice coil. -
the Best way i have found is the peerless is a small hole in the middle of there dome i think is a give away that's it's an older setThere is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm
