Computer help
Jhayman
A friend asked me to look at their computer it was not booting up just kept rebooting..
Anyway they are running Windows XP and I'm running Windows 7 I have pulled the hard drive from their computer and put it in my dock to save her data..
The problem I'm having is every time I try to copy or open a file it says I need to enable permissions to access these files and or folders.
Then it presents me with the security screen and permissions but I don't know what to select in the windows, I have selected my computer name and admin name but it still won't let me open these files..
Even when I click on a file that has a .wrd or excel ext, the program opens and it says you don't have permission or you need permission to open these files..
I need to save them for her on a USB.
Any helpful advice would be Greatly appreciated Thanks
Post edited by Jhayman on
tough one, I understand it would say that if you try to access the files, but to just copy them is a real teaser. Have you tried just copying the whole disk onto another? I hope you have the code number off their computer, I recommend a complete re-format and install of XP, as it sounds like they have some bad dll files keeping the OS from booting.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
Thanks Recoveryone...
I got help on another site, it's in the permissions but you have to change more than I did..in the owners tab..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
