Recommend a common ground power amp to drive SDA's.
hifi junky
I'm still in search of a common ground power amp to drive a pair of SDA 2B's, with the use of the interconnecting cable.
I would like something vintage 80's- early 90's, with display VU or digital, LED meters ect.
I was inquiring about a Nikko alpha lll, though I think it is only 80 wpc. I think it would be under powering my speakers as it has been recommend to use a amp producing 200 wpc.
Any recommendations or opinions would be greatly appreciated.
Thanks.
Thanks.
Post edited by hifi junky on
Parasound HCA 1500a sounds great with 2Bs. 205 wpc and can be had for 400.00 or less
hifi junky wrote: »I would like something vintage 80's- early 90's, with display VU or digital, LED meters ect.
Thanks.
While we all dig VU meters, finding a vintage piece with enough juice may be problematic....at least cheaply anyway. Parasound or B&k amps are the go to amps for cheap and quality sound that punches well above their price points. If quality sound is important to you anyway.HT SYSTEM-
lsi 9's -
You already started this thread:
http://www.polkaudio.com/forums/showthread.php?159370-Recommended-common-ground-power-amp -
How much money you got LOLKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
