HDMI switch
krabby5
krabby5 Posts: 923
edited March 2014 in Electronics
Hey All,
I have an older Pioneer Elite 72txv receiver that has 4 HDMI inputs that only output 720p. Because of this, I plug all of my HDMI cables into the source tv. I also have a Logitech remote to control everything.
I am constantly having problems with the tv either not switching to the correct input or it attempts to switch too early. So, for example, when i push "Play PS3", the tv sometimes doesn't go to the correct input. I have tried all sorts of fixes in the Logitech software (input lag, etc), and it still doesnt work properly. So I am constantly pushing the help button to fix everything. It really causes problems when other people are using the remote.
Would having an HDMI switch help alleviate this problem? I figure i could just plug all my devices into the switcher and have one output HDMI going to my tv, thus bypassing having to switch tv inputs.
Anybody else do this? Would I be adding more problems?
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
  • PSOVLSK
    PSOVLSK Posts: 5,381
    edited March 2014
    It should work, but it may not work as well as you'd like. I used one and for the most part it worked well, but sometimes my Harmony One wouldn't change the input on the HDMI switcher. No problem for me, but big trouble if my wife or kids were turning trying to watch something.
    Even with the switcher it's going to be incumbent on your Logitech to get the input changed.
  • TurboGTU
    TurboGTU Posts: 187
    edited March 2014
    What kind and model tv do you have? Does it have individual remote buttons for the sources or is it only the toggle list type. I used to have this problem on my westinghouse tv because it only had 1 hdmi source button that would toggle through the 4 inputs. My new samsung has buttons for hdmi1 and hdmi2 abd I know longer have issues with the harmony (except after you drop it and it reboots, but that's a different problem entirely).
    If the case above is correct, then it is very possible a separate hdmi switcher will help. Make sure it has separate remote buttons for each source before you get it though or you will be in the same boat.
    The remote tries to track the source list, but in my experience it does a horrid job and works far less than it mucks up. Good luck!!
  • krabby5
    krabby5 Posts: 923
    edited March 2014
    Turbo,
    I have a Toshiba that has 4 hdmi inputs. It has about 8 sources with individual remote buttons. So HDMI 1 might be number "4" on the input selection. The problem is I can't figure out the input lag to set..nothing seems to work properly. The input source button is selected too early and doesnt correspond to the input change on the tv. So when i am playing PS3 (Play PS3), and switch back to "Watch TV), the input selection works on the remote but I think it is doing it too fast, and doesnt alwatys switch the tv correctly.
    Maybe I just need to dig in and get it right! It would be a lot easier if I just used the receiver for switching, but then it only outputs at 720p..ugh
    tonyb Posts: 33,072
    edited March 2014
    You have to set up the inputs on the tv just like you do for a receiver. Also, changing inputs usually works better when using the remote that came with the TV. Though Logitech is usually pretty solid in that, some other universal remotes can have some lag.
    Maybe time for a new receiver ? If it's only doing 720p, it's probably not also doing the newer surround codecs your missing out on.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2014
    Hi Krabby, +1 on maybe time to upgrade the receiver to 1080p. Within the last year or so, there have been a number of threads here on folks getting some really_ nice deals on Pioneer Elite AVR's .
  • krabby5
    krabby5 Posts: 923
    edited March 2014
    yeah..I know getting a new receiver would be great, but other than not using the HDMI inputs, I love that receiver. Never had one problem with it and it's been on everyday for at least 5-6 hours since I bought it new back in 2006.
    I've since downgraded to an apartment and having new codecs wouldn't really make that much of a difference anyways. Can't turn it up loud enough
    I'm sure I'll get a new receiver one of these years, though.
