best wall mount for 40" LCD TV
danger boy
danger boy Posts: 15,722
I just replaced my living room TV with a larger screen.. very happy with it.. Samsung UN55F7100AFXZA 55" LED stunning picture quality and color.
so I want to move the 40" LCD tv to the spare room.. but i'd lilke to mount it on the wall..
TV weights 47 lbs. more than the newer one.. lol
any help, info, suggestions, would be great.
thanks.
PolkFest 2012, who's going>?
  • recoveryone
    recoveryone Posts: 930
    edited March 2014
    You can get good mounts about anywhere now days, it mainly depends on what your needs/desires are for the mount. If the TV will sit sit on a wall no tilt or other features then head over to wal mart and pick one up between 30-50 bucks. If you are looking for more features tilt, swing out arm and others I stick with the sanus brand, a bit more costly but the build quality is there.
  • ken brydson
    ken brydson Posts: 9,107
    edited March 2014
    Best prices and selection at Monoprice...
    edited March 2014
    I just picked up a Sanus wall mount for my bedroom 40 incher. Tilt, adjustable, easy to take the tv off without removing the whole bracket, tv can slide a bit too either way. The cheaper wall mounts don't allow for adjusting or tilt after the installation like the better brands. Granted, they are more expensive but well worth the extra 40-50 bucks. I think mine was 90 bucks and can be had at any big box store.
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2014
    Can't beat Monoprice. Great quality and cheap price. Just bought a tilting wall mount for my 50" Panasonic plasma. Excellent mount.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • czarodzi
    czarodzi Posts: 38
    edited March 2014
    Whatever you do, look online. It is SCARY how much more the big box and appliance stores charge! I've been very happy with Peerless for the last couple wall mounts I've installed.
