2.5 Way
VR3
VR3 Posts: 29,762
edited February 2004 in Speakers
The RTi70 is a 2.5 way. There is NO way the bottum 6.5" midbass is playing the SAME signal. The top driver plays ALOT more vocals and other areas than the bottum driver. To me, this says that *duh* more information is going to the top driver. Which would also mean this is a 2.5 way....no?
  • Airplay355
    Airplay355 Posts: 4,298
    Crossover 2.1kHz between mid-bass drivers and tweeter; 2nd order HP/LP complement. Mylar bypass capacitor in HPF.
    wouldnt there be two different crossover points then? one for the tweeter and the top woofer, and one between the top woofer and the bottom woofer?
    why do you tink its 2.5 way?
    edit - i just unhooked my tweeters to prevent any highs from bleeding into the midrange since the woofers are not equally distanced from the tweeter. they sound the same to me, and feel the same if i put my finger on them. idk whats up with urs.
    VR3 Posts: 29,762
    hmmmmmm...............let me see here
    They sound the same you are right, but the top driver seems *ummm* louder than the bottum? I dunno.......
    Oh well, just a thought......i need to sleep more:o
  • brettw22
    brettw22 Posts: 7,623
    Sid, don't you have something better to do than to be hugging your speakers? Good lord......find something with a pulse. ;)
