Clean up all wires and accessories - ir blaster?
Vital
Looking to leave nothing but TV unit itself and Polk's 6000 sound bar on the wall.
I have space to play with on the other side of the wall so I can have all my wires there as well as Cablevision's TV box, I just can't put my finger on how to still be able to control that tv box via remote while it's behind the wall.
Someone told me to look up IR BLASTERS but the ones I keep finding are either bluetooth depending or limited to specific brands of items.
I assume there should be some kind of sensor that would "catch" tv box remote control signal and "transfer" it appropriate units - TV, cable box, external speakers, DVD player, Roku, Apple tv, whatever else people normally use.
My units:
Samsung tv
Cablevision tv box (happens to be samsung as well but that can always change)
Polk Audio 6000 sound bar
My units:
Samsung tv
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Kenwood DNX 5140
Post edited by Vital on
I believe you want an IR repeater like this:
http://www.smarthome.com/59501/Smarthome-SELECT-Hidden-IR-Repeater-Kit-with-Surface-Mount-Sensor/p.aspx// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
i bought the logitech harmony smart control ..
comes with a remote and the app is free if you want to use it on your phone
supports RF and IR -
+1 on the smart hub. Its simple, includes blasters and works very well.Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
I use the Harmony Ultimate myself because I wanted a physical remote without always having to use a smart device. I just wanted to recommend something that wouldn't have to completely replace his current remote.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
Photo Gallery
I use a Sewell BlastIR Emitter and Receiver to receive the IR signals from an "eye" and pass them to "flashers" aimed at the equipment in a cabinet. The brains of this are in a box and since the "flashers" connect to it with 1/8 plugs I tried to connect to my revceiver with a cable that has 1/8 plugs on each end. Trying to get answers from Harman Kardon support on actually connecting this was a frustrating waste of time, they always suggested their own (and more expensive) IR solution. (I thought hey, if I fry something I get to upgrade. Who knew it would actually work?! Woo hoo!)
Also have a Logitech Harmony 650 to consolidate the controls and combine functions. The only drawback is that my Verizon FIOS box uses a different frequency so I have a second "eye" for it also outside the cabinet.
From behind the Polk Soundbar 42 there are two eyes watching me watching TV! -
+3 on the Harmony Smarthub, the regular comes with a simple remote and can manage like 6 devices, the ultimate comes with a better remote and an unlimited number of devices.Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Center: Polk CS245i
Console: Xbox360
