Polk LSiM705 vs other floorstanding speakers near or under 2.5k
pyrocyborg
pyrocyborg Posts: 524
edited April 2014 in Speakers
Hi!
I’m looking for some input concerning the overall quality of some of these speakers (2 ch. stereo : 80 music/20 movies). My budget is around the 2k/2.5k CAD, I prefer a new speaker as I want to be able to demo it in my room, and also because I can’t find anything interesting on Canucks Audio Mart right now (at least, within my taste and budget).
Here is what I could get:
Bigger 3 way tower speakers :
- Polk LSiM705 (2400$, maybe less... would probably wait for them to go near the 2k mark)
- B&W CM8 (2400$)
- Focal Chorus 726 (2000$)
Smaller tower speakers like:
- Totem Sttaf (2100$)
- Vienna Acoustic Bach Grand (1700$)
- Focal Chorus 716 (1700$)
Thing is smaller towers might not cut it as my living room will be kinda large (11x14 ft with some rear and side walls, but this is within a 450 sq ft open floor with the kitchen and dining room). I’m kinda tired of the tiny sound my LSi7 produce in such a large and sub optimal room. I liked them in my old living room, but now, I wish they were bigger. Small towers could be better, but still, they would most probably probably need a sub.
I’m not sure I want to go with bookshelf speakers as I would need some sturdy stands (200-300$ or more?) and a good subwoofer, which would roughly cost the same than bigger tower speakers. Plus, I do prefer the look of a tower, and I might not want to mess around with subwoofer placement.
Anyways, I’ve heard the LSiM705 in a less than optimal room (read Futureshop/Bestbuy kind of shop with no dedicated listening area). The room was a 15 ft x 15 ft area within the store with little to no walls except behind the speakers. The speakers were to able to give better bass, imaging and overall sound than my LSi7 do, but yeah, these are towers that cost 5 times as much as my little bookshelf speakers, so this is expected.
However, I was disappointed by the Midnight Mahogany finish: I thought it was brownish/purple, not completely dark with a very slight hint of purple… but the sound quality kinda made up for it. I was amazed, to say the least, and these were driven by a 50w per channel Marantz NR1604. I even tried the LSiM703 and they sounded incredible in less than stellar position (on a metal shelf and not in a dedicated room). So yeah, I have the LSiM705 as my benchmark now. I could also try them at home for 30 days and send them back if I’m not happy with them, thing I couldn’t do with others brands because they could only be bought from smaller shops with no return policy.
Anyways, there is not a lot of dealers around here and choice is somewhat limited. I would like to try the KEF offering in this price range, but there is no dealer around that carries this line, at least, not that I know of.
How do the Polk LSiM705 compare in term of built quality and overall sound quality to the rest of my small list? Considering that they are built in China, they must be a “better” deal in term of drivers quality, right? They are by far the heaviest in the group, too.
Thanks a lot!
Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H
Post edited by pyrocyborg on
  • pyrocyborg
    edited March 2014
    Thanks for the suggestion, very nice looking speaker indeed. From what I can see on the Usher Audio canadian website (Audioscape), there might be a dealer near. Guess I'll have to call them.
  • pyrocyborg
    edited March 2014
    I've seen a pair of demo Dynaudio Excite X32 with some surface scratch for 1800$. However, these are less sensible (87dB) and 4 ohm speakers that might requires more power than what my poor NAD has to offer.
    F1nut Posts: 51,795
    edited March 2014
    Not sure how open it is, but 11x14 is a small room. Anyway, you say the sound doesn't fill the area as it did in another house. I'd say the problem is more a lack of power than the size of the speaker, so I'd suggest upgrading that first, then see where you are. That said, the 703/705's are much better speakers than the LSi7's.
  • rromeo923
    rromeo923 Posts: 1,513
    edited March 2014
    I was not really impressed with LSi7's that I had. For 2k you could get a very nice set up that would sound awesome. Maybe a used Tube integrated and some SDA's??? Or whatever. Used Vintage speakers can be found so cheap and you can always recap etc. I was listening to a pair of Kef 107/2's last night that were absolutely amazing. So many possibilities. You are so lucky!!
    I got static in my head
  • pyrocyborg
    edited March 2014
    Well, I wasn't clear, but that 11x14 "area" will be in my next apartment (few months from now).
    Right now, I'm in an L shaped open floor which serves as a living room/dinning room and communicates with other rooms (roughly, this area is about 400-450 sq ft). The speakers have to fill the entire room, which is almost impossible for speakers that size without increasing the volume. I mean, my NAD has absolutely no problem driving the LSi7 at uncomfortable level, but the shape of the room, and the position of the speakers in that room aren't optimal: thus, at high volume, they still sound thin and lack deep bass where they sound great in a small 11x13 closed room (with 4 walls and a door!). I can't feel the sound surrounding me the way it does in smaller rooms. Maybe it's the room fault, I don't know...
    I don't think giving them more power and thus, a 3 db or 6 db increase in volume, would help them as I prefer to keep the volume down.
    Here is a floor plan of my next apartment. The speakers will be positioned in the 11x14 "area". Still, there is no wall and it opens directly to the dinning room and kitchen. I don't think that the sound will be limited to the 11x14 area. That's why I can't consider it a small area, but probably more like a moderate size room.
    Here again, I have no idea of how it would sound in there. Sure thing, if they sound great where I am at the moment, they probably will sound better in the next one.
  • pyrocyborg
    edited March 2014
    rromeo923 wrote: »
    Well, for my part, I like my LSi7 but there are more of a small study or office kind of speakers. On speaker stands, they sound detailed enough and can fill that small area. However, in a room larger than 200 sq ft, they simply won't cut it IMO. Did great with a subwoofer in small to moderate sized living room, but right now, such a small box can't fill that much space at low to moderate volume. I understand, however, that not everyone loves them. They're kind of a laidback pair of speakers, detailed, but really not "in your face".
    As for my budget, if I could go lower, I would... However, I want to go a step up from the LSi in terms of overall quality so it definitely means more money.
    I don't think I could get new electronics. I prefer to stick with what I have right now. As for the SDA, I bet they sound incredible for the price, but they probably wouldn't be a welcome sight in my living room: WAF. And yeah, I need something stylish, piano black or quality wood finish. Anyways, there are no SDA around here... :P
    F1nut Posts: 51,795
    edited March 2014
    Ok, I gotcha now. Being that you are moving soon I'd just wait until then to do anything. That said, those 705's are damn nice sounding speakers that should work well in either residence. I still think you need more power tho. :)
    BTW, I don't think SDA's would be a good idea in your new place.
  • pglbook
    pglbook Posts: 2,262
    edited March 2014
    Have you thought about PSB speakers? Being a Canadian company, they should be easy to find near you.
    I have not heard their totl speakers but I know they get great reviews and people swear by them.
    I own a pair of the original PSB Stratus model and love them.
    I can only imagine how nice the totl model is.
  • drummer86
    drummer86 Posts: 441
    edited March 2014
    I've heard good things about the PSB Imagine T as well. Other Canadian options would be Totem and Paradigm. Both have solid options in your price range. I think those Focal Chorus towers would be outclassed (not even close) by the other options you listed. Their higher end stuff is very good though.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • pyrocyborg
    edited March 2014
    Woah thanks for your answers! ;)
    PSB is a nice idea, but I can't find anywhere near that carries the Imagine line. They all carry the Image, but that's about all.
    Yeah, more power, the better? ;)
    I'm sure it probably will sound better with a beefier amp, but considering that I will probably never drive them near clipping level on my NAD, I'll try my next speakers with what I have right now. Probably won't sound at their best, but might still be better than with the 7.1 receiver they used in the "showroom".
    I mean, as I said, on my LSi7 (88 dB sensitivity if I recall well), my 50w NAD can drive them properly using a small amount of power (e.g. considering "off" is at 7 o'clock; I can get to very high volume at 11 o'clock). However, I'm only 9 feet away from my speakers, so that might help.
    I guess you're right that I should wait and make my demoing in that particular room. It's just that I would like to have speakers that could fill the entire listening area. ;)
    txcoastal1 Posts: 13,513
    edited March 2014
    The 705's aren't terribly power hungry and the NAD will get you by, at LSAF Russ ran the 705's on a single ended integrated.
    http://www.polkaudio.com/forums/showthread.php?128877-LSAF-Lone-Star-Audio-Fest-2012-May-4-6/page3&highlight=lsaf+2012
    If you are running dual duty HT more power definitely recommended.
    But take your time big purchases earn as much evaluation as possible.
    Good luck w/your search
    Cheers
    Ron
    F1nut Posts: 51,795
    edited March 2014
    Sure a more powerful amp will allow higher volume levels, but it would also make the speakers sound better at low volume levels. That fact escapes a lot of folks.
  • WLDock
    WLDock Posts: 3,073
    edited March 2014
    rromeo923 wrote: »
    I remember in the early 90's I was buying some car audio gear from a guy. As soon as I walked in his place I saw that he had 107's set up powered by a couple Denon monoblocks and a Nakamichi source. I asked for a demo and he put on the Dave Brubeck Quartet, "Take 5" cut. Being a jazz drummer myself I was floored by the overall presentation and how detailed and real the drums sounded. That was the first time I heard that track where the drums actually had weight! I haven't heard the old Kef's since...but would love to!
    ..and the used market is filled with these gems if one is lucky to find a pair in their area:
  • Msabot1
    Msabot1 Posts: 2,098
    edited March 2014
    New ones? 705's are hard to beat...as long as your source has plenty of headroom...
    tonyb Posts: 33,072
    edited March 2014
    Just my .02, but if your going to move up to towers, your asking a lot of that Nad to fill the room with sound as you put it. Right tools for the right job and all that ya know.
    Not sure how loud you can crank it being in an apartment, but any amp isn't going to deliver it's rated power at lower volumes. You solution to fill the room with sound....in an apartment, may be multiple smaller speakers playing in all channel stereo that are efficient enough to use lower powered electronics. Just a thought is all.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2014
    pyrocyborg wrote: »
    ...I'm sure it probably will sound better with a beefier amp, but considering that I will probably never drive them near clipping level on my NAD, I'll try my next speakers with what I have right now. Probably won't sound at their best, but might still be better than with the 7.1 receiver they used in the "showroom".
    The purpose of getting a powerful amp is not about volume, its about making sure that your speakers have the power to operate to their full potential at ALL volume levels. This was the biggest most pleasant surprise that I got when I got the Parasound 1500A and put them on my RTA-8Ts. I picked up on things in the music I never heard before even when I cranked the volume. Loudness does not equal clarity. I no longer had to increase the volume at 6 in the morning and still could hear every detail of my music.
    I passed the Parasound onto my brother to drive his LSI 7s, it made a huge difference over my old 50wpc Rotel that he was using. One of the biggest differences was the amp stayed comfortably warm rather than fry an egg hot that the Rotel got!
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited March 2014
    There's a pair of Wharfedale Opus 2-2s on ebay. They've been sitting there forever. New in box, at a price far below their previous asking price. Crazy good midrange and nice bass weight. They're in the piano birdseye maple.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • pyrocyborg
    edited April 2014
    Hi!
    I sold my LSi7 and I'm looking for a pair of tower speakers.
    I tried to find some PSB Imagine Towers, but sadly, there are no PSB dealers within 300 km that carries that line...
    A dealer is selling some Focal Chorus 836 V at discounted price ($2000 here), but I wonder how good they are compared to the 736... and here again, I guess I would need a powerful amp to drive them. Sure thing, I could try Totem too, but their larger speakers are out of my budget... I must keep some money to buy a bigger amp in the near future. :P
    I'm still waiting for the LSiM705 to be on sale again (near the $2000 price point), but it seems to happen once a year in Canada... lol.
    Any other ideas? Thanks a lot!
    edited April 2014
    IMO. Focal towers do not pull away from the pack until you're in the $4K plus a pair category or even higher! So I'd think the Polks might be a top pick below that!
    cnh
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2014
    I love my LSiM 703s and have nothing but positive thoughts on the LSiM series, but given the wattage of your NAD integrated, I would also consider these:http://www.zuaudio.com/loudspeakers/omen-1b, or these: http://www.zuaudio.com/loudspeakers/soul. A little power goes a long way with them and they sound great! I tried older NAD power envelope 2400 and 2600 amps with my ZU Omens and it was a great match. ZU ships the speakers directly to you and offers a 30 day no questions asked refund if you are not completely happy. If you want a really good deal check out the Omen Dirty Weekends (new cabinets with used drivers that were traded in for the new nano driver upgrade) that can be had for $1000 US and have a full warranty and guarantee. Just contact ZU direct about them, they have some available right now.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited April 2014
    DSkip wrote: »
    I don't care for PSB personally, but I can give a thumbs up for Totem. You'll need some watts behind the Totems to open them up though. FWIW, I'd probably take the 705 over the Totem due to a fuller sound.
    I've owned the flagship PSB Synchrony's and am now rocking' the Totem Hawks. I much prefer the PSB house sound.
    To the OP, be sure to look into PSB!
  • Polk&Beans
    Polk&Beans Posts: 94
    edited April 2014
    Listen to the DawgFish. Get the 703's. Best bang for the buck and better in a smaller room...
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited April 2014
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    tonyb Posts: 33,072
    edited April 2014
